Edited by Mazzy, 28 December 2015 - 12:50 AM.
Boost Pressure? + Turkey Noise Issue
Posted 28 December 2015 - 12:47 AM
Posted 28 December 2015 - 01:26 AM
Posted 28 December 2015 - 09:37 AM
Issue I have now is Boost Pressure... I did a run/log using Torque App and the peak boost level running through 3rd gear is 29-30PSI.
Car was mapped and setup by CS. Why would they have set the actuator to this? Shall I wind it back? What level?
30 PSI is very very high, something is badly wrong. I'd try and fix that before driving hard or your turbo will not like it. As you say, the first thing to look at is the wastegate getting stuck shut for some reason, may be mechanical (actuator too tight or penny valve getting stuck shut) or might be due to a faulty solonoid (mounted on the turbo housing) or its associated vacuum pipework.
GL.
Edited by Nev, 28 December 2015 - 09:38 AM.
Posted 28 December 2015 - 09:49 AM
Posted 28 December 2015 - 10:21 AM
Posted 28 December 2015 - 10:38 AM
I would back off the wastegate actuator preload a bit , I think chances are you have a solenoid that could need cleaning out , or the actuator needs replacing. The uprated actuators CS sell don't seem to be very robust / suffer from heat.
Posted 28 December 2015 - 10:45 AM
Posted 28 December 2015 - 10:50 AM
Yep this.. wouldn't trust the psi from your app, even opcom captures the same.. which is 2x boost + xx something added (can't remember what tho) Best you check your boost gauge for a true reading.Is that gauge or absolute pressure for a start?
Posted 28 December 2015 - 10:57 AM
what you might see in opcom is engine load ,
For example, load of 120 , the formula is 120+30 *10=1500mbar, or 0.5 bar boost. *
* corrected to atmospheric conditions and altitude by ecu
Posted 28 December 2015 - 11:39 AM
Posted 28 December 2015 - 11:58 AM
yes, wastegate actuator and control solenoid is part of turbo unit when replaced , but not the recirc solenoid.
give them a good clean through with brake cleaner spraycan
Posted 29 December 2015 - 05:41 PM
Edited by Mazzy, 29 December 2015 - 05:43 PM.
Posted 29 December 2015 - 06:36 PM
