Project Fracas - 6Sp A20Nft
1268 replies to this topic
#301 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 30 May 2016 - 05:01 PM
agreed
My bolt supplier's default for socket head cap screws is 12.9, so its become a bit of a habit of mine just decking everything out with them. but from an actual torque specification point of view 12.9 is overkill for 90% of fixation applications.
#302 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 30 May 2016 - 05:07 PM
Thats standard for cap heads, 10.9 is considered a special by most industrial bolt suppliers. I asked at work to get some on stock ;)
#303 Nev
Posted 30 May 2016 - 05:10 PM
I simply came to the conclusion that less stretch and higher clamping forces of 12.9 can only be better. Maybe I am wrong, but 3 or 4 years of aggressively bashing though B-roads pot holes, dips, cattle grids etc and they are still fine. Bear in mind I also have the widest/gripiest road tyres of any VX220 I know of, the most torque of any UK VX220 and also the heaviest VX220 in the UK (950 KG wet) means they get tested quite hard, and repeatedly so every few days. I am just adding my tuppence worth to reduce risk for other owners, based on genuine experience :)
Edited by Nev, 30 May 2016 - 05:13 PM.
#304 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 30 May 2016 - 05:22 PM
I dont think its bad at all. infact if it looks like i need to replace mine, itll be with 12.9.
Im a little more concerned with the pseudo engineering knoweledge ive waded through on various lotus foums tbh!
#305 SteveA
SteveA
  • 9,156 posts
Posted 31 May 2016 - 10:07 AM
:yeahthat:
I was speaking to an expert about stress testing of suspension components and was told that UK roads are a much more aggressive test than the heavy G loading of track driving. Apparently because the travel frequencies are much more varied and violent (e.g. from a pot hole etc.)
#306 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 10 June 2016 - 12:28 PM
Massively important update... my Chinese centercaps turned up
#307 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 14 June 2016 - 08:01 PM
More overnight parts from China
Relatively enormous 70mm tanks, 56mm double row core
It included 2 ShinzenCo. fans but I think I'll dig out some 10" Spals I've got got kicking around here somewhere.
#308 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 14 June 2016 - 08:09 PM
And as the kids have been sick and I've been stuck around the house...
If anyone's interested, it's Foliatec 2K hi temp, comes in a 2 part rattle can, really high pigment, flows well. good stuff to use, but be fcuked getting it off your hands
#309 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 15 June 2016 - 08:11 PM
So... This took longer than it should've.
Basically only had to demount the ShinzenCo fans, mount the 10" Spal, and mount the IC cooler and its 8" fan. Problems popped up with how the 8" fan sat on the cooler core, fouling the crashbox. Not helped by how goddamn thick the new radiator is. So I had to rethink how I was mounting the IC cooler altogether. I ended up mounting the 8" on the top of the main radiator (flipping the fan blade turning it from push to pull). I actually still managed to line up the fan mounts on the IC cooler, so the fan sits correctly over the core, now just with a 56mm rad core sandwiched in between. Getting that all lined up top and bottom so the IC core and fan didn't foul stuff was a bunch of fun.
Anyway, couple of pics below. Rad core dwarfs the IC core now. Not that it was particularly big to begin with, but now looks tiny. Also a decent shot there showing exactly how much the new rad fills the surround to the brim.
#310 Arno
Arno
  • 1,238 posts
Posted 16 June 2016 - 07:42 AM
Can't make it out on the photo, but just in case.. Make sure you fit some plastic/nylon/foam strips between the main rad and the chargecooler rad to limit the conductive heat transfer from the (potentially hot) radiator to the CC rad and into the CC circuit.
#311 siztenboots
Posted 16 June 2016 - 07:52 AM
Is that fan attached with self tappers into rad?
#312 fezzasus
Posted 16 June 2016 - 07:56 AM
Photo shows bolts, nuts with penny washers spreading load.
#313 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 June 2016 - 08:13 AM
lol wat?
#314 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 June 2016 - 08:29 AM
Can't make it out on the photo, but just in case.. Make sure you fit some plastic/nylon/foam strips between the main rad and the chargecooler rad to limit the conductive heat transfer from the (potentially hot) radiator to the CC rad and into the CC circuit.   Bye, Arno.
theres self adhesive rubber edge strip between the 2 cores. i put it there mostly due to the fan now pulling through 2 cores, but itll act thermally as well. good idea!
#315 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 16 June 2016 - 09:29 AM
Love the centre caps Ed, where'd you get 'em from?
#316 Arno
Arno
  • 1,238 posts
Posted 16 June 2016 - 09:37 AM
perfect! thumbsup
As you already thought of the second advantage is indeed to seal the rad(s) together so any air drawn/pushed through them will not leak out between the cracks and reduce the efficiency. Air is lazy and wants to take the path of least resistance :D
#317 siztenboots
Posted 16 June 2016 - 10:29 AM
lol wat?
okay, thats how its done
#318 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 June 2016 - 08:56 PM
perfect! thumbsup
A pic thereof :)
Also had to drill out some hose fittings as the ID was unexpectedly small. Am running 32->25->19mm hose from pump to core, keeping the 19mm stuff as short as possible to minimize the flow resistance.
#319 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 17 June 2016 - 06:30 AM
the centercaps themselves are just some generic unbranded 65mm OD, 60mm ID from ChinaBay. though the fingers on the back didnt quite fit the ATS DTC without a little love from the dremel, but they were pretty close, and certainly wont come off the gel dome stickers i actually got from the UK: http://www.ebay.de/i...=STRK:MEBIDX:IT i know some will hate the lotus branding, but its 1000% better than the shitty ATS fake carbon caps. if anything looked like cheap Chinese junk, they did!
#320 O116
O116
  • 5 posts
Posted 17 June 2016 - 11:07 AM
Maybe you will need a domed centercap on the rear rims to have space for the driveshaft.
    Bing (1)
