Project Fracas - 6Sp A20Nft
#41
Posted 14 January 2016 - 11:11 AM
#42
Posted 14 January 2016 - 11:29 AM
I've got an image host set up on another forum, but the way the forum prefs are set up here, it won't allow embedding/linking of that image type... *shrugs* ... I'm not going to setup a new photobucket account just for a few forum posts.
Then you're posting some weird link as the site supports all usual image types, otherwise there'd be no images here whatsoever.
#43
Posted 14 January 2016 - 12:00 PM
the irony of your rolling eyes lies the fact that these forums are riddled with dead images
yes, i was trying to link something other than a gif or jpeg. not terribly unusual for forums though.
#44
Posted 14 January 2016 - 01:38 PM
so... just for you guys, perhaps someone will find its useful
part 1 - plain jane, flows like a brick
#45
Posted 14 January 2016 - 01:44 PM
part 2 - big ass diffuser + 2 element wing
(diffuser is cut about 80mm up into the rear bumper, lower doesnt really seem to do much)
of note is how the wing and diffuser work together, i was mostly looking at the diffuser function here. wing function is probably not brilliant due to the crappy zone of air over the engine bay, but its effect on pumping the diffuser is quite good.
#46
Posted 14 January 2016 - 01:47 PM
and part 3 - same diffuser, just run without the wing. no surprise really, diffuser reduces drag from the brick shape butt-zone, but from a downforce point of view is prett much sitting on its hands without the wing
#47
Posted 14 January 2016 - 02:21 PM
and finally... how badly can you flow a wing? about this bad! coupe back, massive wing, something something....
#48
Posted 14 January 2016 - 05:37 PM
If it is of any help, I did some experimentation with lowering the front of the car down, once the nose is 7 CM above the tarmac (and in my case a big wing above the roof level) I got fantastic and strong down force on the front at speeds of 90 leptons+. Once I raised the front up to about 11 CM that downforce was more or less gone. I now have the front clam around 9 CM from the tarmac and have some meaningful frontal down force from around 110 leptons.
#49
Posted 14 January 2016 - 05:53 PM
#50
Posted 16 January 2016 - 10:24 AM
What have you done to make it flow bad? Or how do you mean flow bad?
Would you like to make a imulation with that big diffuser and a low small rear wing?
Br, Per
#51
Posted 16 January 2016 - 01:35 PM
#52
Posted 16 January 2016 - 02:22 PM
I like this very much nice work. what if you make a longer roll bar cover, mini coupe back? It´s much simpler to do and could maybe give same effect?
Or vortex generators on the rollbar cover?
Br,Per
#53
Posted 16 January 2016 - 02:52 PM
#54
Posted 16 January 2016 - 03:22 PM
Ah, now I understand your text with that pic better; "and finally... how badly can you flow a wing? about this bad! coupe back, massive wing, something something...."
The coupe back, massive wing, somethin are your options to make the wing flow betten than on a standard body.
Nice work. Did you ever look to the work of Winstar on here? He did some flow modelling on diffusers
#55
Posted 16 January 2016 - 03:38 PM
^^^ exactly. sorry, just jotting rather than writing properly
and soooo... on that point. a basic coupe back. is already 11ty times better than the std rear clam...
#56
Posted 16 January 2016 - 07:35 PM
#57
Posted 16 January 2016 - 07:43 PM
nope, its not going to change a whole lot
#58
Posted 17 January 2016 - 09:34 PM
On the other hand, I tried a bigger, taller (and wider element) wing this morning.it works well. Not very unexpected.
Good to see some positive feedback on my own greatly maligned "big + tall wing"
Keep plugging, always interesting to see what you post up.
Edited by Nev, 17 January 2016 - 09:35 PM.
#59
Posted 17 January 2016 - 09:36 PM
Does your model include the airflow out of the engine cover?
Flow in/out of the engine cover is virtually nill. People really need to understand/believe this basic fact as the whole area is stalled apart from the last 30 CM near the boot spolier.
Edited by Nev, 17 January 2016 - 09:38 PM.
#60
Posted 18 January 2016 - 01:16 PM
