Project Fracas - 6Sp A20Nft
#581
Posted 05 July 2017 - 02:17 PM
#582
Posted 06 July 2017 - 09:11 AM
if i can just flip the actuation lever orientation at the gearbox end...
Edited by Doctor Ed, 06 July 2017 - 09:16 AM.
#583
Posted 06 July 2017 - 02:16 PM
#584
Posted 06 July 2017 - 02:28 PM
flush-mount freely rotating hardened steel linkage roller
Should we start a list?
#585
Posted 06 July 2017 - 02:46 PM
#586
Posted 06 July 2017 - 07:48 PM
Any photos ?
grinder and paint makes you the welder you aint
and for the real keen beans... the linkage 'roller' (which is originally a plastic bit, that wears and makes the gate movement sloppy) i remade using the cut-off end of a tapered gudgeon pin from a dead 125cc 2 stroke piston, inserted a M10 rod through it, hammer-flared the end of the shank so it engaged the taper, passed the rod through the plate and welded it to the plate from the backside. so now have a flush-mount freely rotating hardened steel linkage roller
I cannot figure out what you did....
Thanks
#587
Posted 06 July 2017 - 08:23 PM
ill take a pic tomorrow of it installed
#588
Posted 07 July 2017 - 06:47 AM
...of?
People interested in this mod, I guess.
Waiting for the photos
#589
Posted 07 July 2017 - 03:05 PM
i think thats a little easier than replicating the entire Europa S mirrored shifter assembly
#590
Posted 07 July 2017 - 03:07 PM
Need to make a proper anchoring bracket for the box-side cable ends, shifter side all lines up and works fine
#591
Posted 07 July 2017 - 03:19 PM
Good knob choice, it's nylon, right?
Are you happy with the level of flex from the original shifter assembly?
Edited by fezzasus, 07 July 2017 - 03:21 PM.
#592
Posted 07 July 2017 - 06:03 PM
#593
Posted 10 July 2017 - 06:57 PM
Edited by Doctor Ed, 10 July 2017 - 07:00 PM.
#594
Posted 10 July 2017 - 07:19 PM
You can see the front square corner of the original vx leading edge poking out. The bottom edge of the std vx door isn't much lower than that, so that's kinda where the s2 door would need to be amputated to close into the vx sill. Also, the door release button you can see doesn't stick out into the door recess very much. Position seems good, but offset could be better. Not sure. Having an s2 door to compare would sure be convenient... but alas, where's the fun in that. It all needs to be chop-suey'd to play with the vx anyway.
Fun and games
#595
Posted 11 July 2017 - 07:02 AM
Great work as always.
I'll be interested to see how the Elise door modification goes together with the VX bodywork (assuming you're not changing the original bodywork??!)
#596
Posted 11 July 2017 - 08:16 AM
im skeptical tbh. the elise/exige sill is much narrower, and cuts under quick quickly from the lower door edge. in comparison the vx sill is quite wide to start with and Drops basically vertically away, so with the massive cut-in for the vent and the generally slim contour of the door panel, ive got a funny feeling its going to look like ass. well see though.
i dont want to modify the sill if possible... thats next level fuckingaround, and i want to Keep the 'basis' of the car original vx (so i can remount oem doors etc as required)
#597
Posted 11 July 2017 - 08:46 AM
The VX wide sills provide better aero down the sides anyway, and get away from the less ideal 'coke bottle' shape of the Elige.
#598
Posted 11 July 2017 - 09:07 AM
oh, i agree! no, no, dont get me wrong, i like the vx sill, just getting the doors to play with it is going to be fun (i need the sweeping countour of the upper door-line so it meets with front and rear clam). rear vent, door profile, and transition from the sills to quarters is simple a challenge.
edit, i cant paste links into Explorer (ughhh) but yeah, think widebody exige GT3 clams
Edited by Doctor Ed, 11 July 2017 - 09:09 AM.
#599
Posted 11 July 2017 - 05:37 PM
see how it works out blending this into the VX
#600
Posted 15 July 2017 - 06:23 PM
