Project Fracas - 6Sp A20Nft
#621
Posted 09 August 2017 - 02:44 PM
#622
Posted 10 August 2017 - 04:56 PM
#623
Posted 18 August 2017 - 03:53 PM
#624
Posted 18 August 2017 - 07:55 PM
#625
Posted 19 August 2017 - 10:36 PM
#626
Posted 20 August 2017 - 02:05 AM
#627
Posted 20 August 2017 - 06:18 AM
#628
Posted 20 August 2017 - 08:52 AM
Be fair to yourself mate that's not bad at all! Only thing I can see wrong is it's not straight all the way around but unless you have a jig that rotates you will never get it perfect. Love your project can't wait to see it finished! I know the feeling of it's not just one it's a 1000 jobs mine is the same!Not good enough to really brag about, but my birdshit welding is actually starting to look like it could hold water.
#629
Posted 20 August 2017 - 04:49 PM
either the daewoo wiring loom has the FR + RR wheel speed sensor inputs swapped at the ABS plug, or the control solenoids/outputs/brake lines are swapped (compared to the Lotus ABS unit).
so which is it? anyone have a Matiz wiring diagram with the pinouts of the ECU control unit?
#630
Posted 20 August 2017 - 09:49 PM
#631
Posted 21 August 2017 - 03:30 PM
#632
Posted 21 August 2017 - 03:54 PM
Is that the sensor that detects excessive G to trigger the bag ?
#633
Posted 21 August 2017 - 04:19 PM
#634
Posted 23 August 2017 - 08:48 PM
#635
Posted 23 August 2017 - 09:00 PM
Particularly happy with the welds on this. 4mm Steel, at least 3mm gap to jump. Did some killer rolling 8's and came up neat as pie.
#636
Posted 23 August 2017 - 09:19 PM
#637
Posted 23 August 2017 - 09:32 PM
#638
Posted 24 August 2017 - 07:00 AM
Enjoying reading this, keep up the great work!
Far beyond any skills I could even hope to have.
#639
Posted 24 August 2017 - 11:21 AM
Meanwhile... I finally got the design for my OEM seatmpunt modification sorted
Simply replaces the intermediate mount plates between the seat rails/base and the seat fixtures themselves. Incorporates the standard seatbelt anchor fasteners etc.
Drops the seat absolutely on is ass on the floor plan, and inclined the seat back further, matching the incline of the fuel tank bulkhead. The head of the seat tucks in nicely under the rollhoop and sits around ~20mm from the glass (so plenty of room for flex without contact).
I'm 6'4" and now have about 3-4" between top head and top of roll bar. Short of a vac-formed custom seat, I'm not going to fit much better I don't think.
Doesn't work obviously with the vx220 headrests, so need to cut those out. Or use an S2 rollbar. Would obviously also work for elise and exige models fine. Can make some to order in case anyone is ever interested.
#640
Posted 26 August 2017 - 11:45 PM
