Project Fracas - 6Sp A20Nft
#641
Posted 26 August 2017 - 11:46 PM
#642
Posted 27 August 2017 - 12:08 AM
It's a ground triggered relay, with the relay itself up the front and the signal (ground) wire running the full length of the car via the cente console. Wire is blue with a grey stripe. Basically just need to manually ground the wire to override the sensor.
Google says people have a intercepted the wire in the center console area, but as that loom ascends to immediately behind the dash anyway, I just attacked the bundle as it appears through the grommet from the footwell area.
Stripped it, found it (deep in the middle of the bundle), spliced a separate ground wire into it. Wrapped it all back up with loom tape... "I was never here"...
As my switch panel are all illuminated toggles, I couldn't just run the signal wire via a simple switch to earth. Is therefore running via a NO relay to ground.
Relay on the left/top is the W2A intercooler fan controller. Relay on the right/bottom is the manual rad fan override controller.
#643
Posted 27 August 2017 - 05:21 PM
#644
Posted 27 August 2017 - 05:32 PM
#645
Posted 29 August 2017 - 10:40 AM
Can't recall from the rest of you thread, but are you fitting a large boot-mounted A2A intercooler and ducting?
Oh, and is that a turbo engine mount? Its not the standard NA part..
#646
Posted 29 August 2017 - 11:07 AM
love catching up on your works every few week, great job.
#647
Posted 29 August 2017 - 11:32 AM
#648
Posted 29 August 2017 - 11:39 AM
I meant the black mount on the engine - it looks like a steel version from a turbo engine, rather than the alloy one. So the M32 gearbox mounts mean you cannot use the original NA engine side mount? Just curious.
The orientation of the MAF has me thinking you were using the boot space - I presume its to be rotated 180 to run along the engine side.
60-80mm 90deg silicone bend with MAF in rough position ready to go
Edited by Rosssco, 29 August 2017 - 11:39 AM.
#649
Posted 29 August 2017 - 05:17 PM
#650
Posted 29 August 2017 - 07:31 PM
#651
Posted 29 August 2017 - 07:32 PM
#652
Posted 29 August 2017 - 09:50 PM
#653
Posted 30 August 2017 - 04:34 AM
i have davies craig electric water pump from my last engine.
if i pull or decide to pull the honda engine apart i will be fitting it to it for that very reason, will fit a timer to it
#654
Posted 30 August 2017 - 01:34 PM
#655
Posted 30 August 2017 - 02:06 PM
Nice.
Is that a large German beer, or wine?
#657
Posted 30 August 2017 - 08:02 PM
#658
Posted 30 August 2017 - 08:33 PM
Edited by Doctor Ed, 30 August 2017 - 08:35 PM.
#659
Posted 30 August 2017 - 08:39 PM
#660
Posted 31 August 2017 - 06:25 AM
Jeeze, so much effort and care going into this project, I'd be scared to drive it hard in case I "bumped" it.
