Project Fracas - 6Sp A20Nft
#681
Posted 09 September 2017 - 05:26 PM
#682
Posted 09 September 2017 - 07:02 PM
Edited by Doctor Ed, 09 September 2017 - 07:05 PM.
#683
#684
Posted 10 September 2017 - 05:49 PM
Fixing the box section is a PITA so I left that alone. What I figured I could do was bang in some rivnuts to maximise the width of the fastener base (or in case of the middle mounting, add a rivnut so there's actually 2 fasteners rather than only one, so atleast there's a faint hope of countering some torque as opposed to a single bolt acting as a simple pivot). Then... and this is where I got all fancy-pants, rather than use stilts/spacers I made one big fuckoff spacer out of 20mm nylon. Every flat surface would thereby be supported, and if bonded properly would be loaded in sheer during twist, and would be rigid as fcuk. To ensure it sat properly on the floorpan (due to rivnut shoulders, and the corrugations in the extrusion etc) I heated up the nylon surface to semi melting with a blowtorch and pressed it onto the floorpan, torqued up the fasteners and let it cool down... hey presto solid as a rock, even without fasteners it's keyed into the floor and has zero waggle. Anyway, so that then got sika'd to the shifter assembly, and it's all fastened up and currently resting over night to cure. First impressions... it's pretty stout and doesn't move
#685
Posted 10 September 2017 - 09:39 PM
#686
Posted 11 September 2017 - 09:09 PM
#687
Posted 12 September 2017 - 07:21 AM
Nothing beats using the kitchen to do car stuff. My personal favourite is putting greasy/dirty car parts in the dishwasher for cleaning!
Apparently my granddad once stripped an entire engine in the bath tub - made my granny furious for years!
Edited by Nev, 12 September 2017 - 07:22 AM.
#688
Posted 13 September 2017 - 06:33 PM
#689
Posted 17 September 2017 - 09:28 PM
So that's inconvenience one, on to number two... hooked up the last of the $peedflow 200series and GM quick connect adapters to the OEM pump (thanks Dale!), and got the tank mounted back into place. Had to bastardise some existing grommets with a blowtorch to pull the 6AN lines through into the engine bay, but got them through eventually... then as I was sorting them out to hook them up to the surgetank fittings, it dawned on me that I trashed 2x olives last time I made some hose, and I'd been meaning to order some replacements... doh! So a couple ordered, just annoying.
So everything is kindve in place, but nothing is really hooked up. Well at least the tank is back in.
#690
Posted 17 September 2017 - 09:41 PM
#691
Posted 18 September 2017 - 03:07 AM
#692
Posted 18 September 2017 - 06:38 AM
the rad surround will need modifying if your going to leave them there, also consider the clam bolts which go upwards right underneath the reservoir they could interfere.
Lotus have attached them onto the cross bar on the wishbone.
#693
Posted 18 September 2017 - 06:51 AM
Edited by Doctor Ed, 18 September 2017 - 06:51 AM.
#694
Posted 21 September 2017 - 05:36 PM
TTV got me my custom flywheel today. Not happy
1 - it's a 7.4kg Nugget without a hint of attempt at weight relief
2 - the clutch disc it's design for doesn't even fit on the friction surface. Inside dia of the disc 165mm. Inside dia of flywheel 168mm (inside dia of pressure plate 163mm). So 1.5mm of clutch disc doesn't have contact with the flywheel.
3 - the spigot bearing is 15.00mm ID as opposed to the 5/7" (18.14mm) specified
So 3 fuckups before even trying to look hard. To be fair, I got near insta-response via email, and without much hoo-haa they're making me another from scratch post haste.
#695
Posted 21 September 2017 - 07:08 PM
are you going to use that flywheel with a M32 gearbox ?
If you are then it's not going to work too well, unless I'm missing something. My custom z22se M32 flywheel is totally different.
#696
Posted 21 September 2017 - 07:18 PM
Edited by Doctor Ed, 21 September 2017 - 07:23 PM.
#697
Posted 21 September 2017 - 07:33 PM
Dug up from several pages back...
#698
Posted 22 September 2017 - 07:27 AM
your measurements are okay, so hopefully the different clutch is the reason why it looked odd
#699
Posted 23 September 2017 - 11:46 AM
meanwhile... just because the other camera was with me
#700
Posted 23 September 2017 - 11:59 AM
Photoshop the stands away and claim to have filled the tyres with Helium
