Project Fracas - 6Sp A20Nft
1268 replies to this topic
#701 vocky
Posted 23 September 2017 - 12:50 PM
yup, dummy fit everything up, and it all works, so the basic dimensions are fine. thrown on the slave cyl is a little short, so seeing as theyre making a new one anyway, ive asked them to increase the depth a few mm to give the slave a little more play room
you don't want the slave to be fully extended, I made that mistake and had to fit another slave with a bigger spacer.
I had a custom (deeper) TTV z22se M32 flywheel made once everything was working okay with the slave + spacers, no spacers are now required.
#702 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 23 September 2017 - 01:55 PM
Yep, exactly. And exactly what I've told them. It'll work as is, but it's cutting things fine. I also thought about spacing the slave, but the opportunity exists to offset the flywheel a few mm, might as well take it :)
#703 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 24 September 2017 - 04:59 PM
trial fitted some 997 GT3 air deflectors / brake ducts. kinda works! :)
Needs a little trimming to work with the swaybar, and to sit properly flush, but pretty damn close out of the box
#704 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 24 September 2017 - 05:15 PM
in case anyone is wondering: Porsche Part Number: 997.341.483.92 - Left Porsche Part Number: 997.341.484.92 - Right
#705 sford
sford
  • 1,454 posts
Posted 24 September 2017 - 06:24 PM
I like that, would work well on the rear too I presume?
#706 SteveA
SteveA
  • 9,156 posts
Posted 25 September 2017 - 08:40 AM
I thought cooling to the edge of the discs like this is more likely to make them warp & crack due to the temp differences across the radius?
#707 chris_uk
Posted 25 September 2017 - 09:20 AM
thought about this idea when i saw them on Jons Gayman, but i also quite like Joes idea of the little ducts stucking out the undertray, something the Elise 220 cup has as well.
#708 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 10:28 AM
They're not fitted properly yet ;)
#709 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 10:38 AM
I wanted to put turning vanes behind the wheel wells, but when I saw the gt3 deflectors I realised it kindve saves me doing that, and simultaneously kills the brake air supply issue with the same simple stone. Im not convinced they're as good as proper brake ducting, but there's so little room for decent sized ductwork, im hoping this will just provide a tonne of air in the right general direction.
#710 Nev
Posted 25 September 2017 - 11:29 AM
Once you get the car running, worth putting some wool strands in the area and installing a tiny camera and take it for a drive.
I suspect the turbulence under there is quite likely to move around in ways that are not at all apparent to the eye.
#711 chris_uk
Posted 25 September 2017 - 12:22 PM
Dropped you a whatsapp ed. :)
#712 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 12:52 PM
menial post-night-shift fumbling around...
Modified the GT3 deflectors to sit properly on the round suspension arm and avoid the swaybar. Use of zipties will ultimately be required. lol
Also finally got my hands on some long stainless muffler hangers. The BMW muffler is nearly a straight fit in the rear subframe, just the standard mounts don't work. So cutting disc and 5mins later, and the base for the new hangers was a go. Welded the hangers, then pulled out the blowtorch and bent them horizontal. Will bolt straight in now, neat as fcuk :)
A bit premature, but have been wondering how to run the exhaust tips... discharging into the diffuser, run a double deck diffuser and run the exhaust into the top deck (blown), or just be normal, and exit normal tips above a simple diffuser and out. *shrugs*. I'll leave that till the bodywork is done. Pointed at the ground will do for now.
#713 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 12:55 PM
Gotcha ;)
#714 Rosssco
Rosssco
  • 4,183 posts
Posted 25 September 2017 - 01:40 PM
That's the muffler of a M135i (or similar) right? I had a thought about one of these before if you ran an Elise-style twin exit out the rear (and avoid using a cat all together).
The standard 3" piping size and exhaust value are appealing..
#715 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 02:33 PM
Bingo :) 80mm inlet, twin 60mm (I think) outlet, one with the loud valve. The controller for the valve is some CAN linked PWM based proprietary thing that I didn't manage figure out. Going to hook up some wastegate actuator to it.
Edited by Doctor Ed, 25 September 2017 - 02:36 PM.
#716 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 06:06 PM
and how that's all kinda supposed to line up:
#717 Rosssco
Rosssco
  • 4,183 posts
Posted 25 September 2017 - 07:25 PM
Cool. So if you rotate the muffler another 45 degrees, it will merge quite well with the cat, and the exhaust tips will come out at around 45 degrees too..
#718 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 September 2017 - 07:43 PM
I'll let it hang though as it is... that's where it wants to settle, so no point fighting the weight. Inlets/outlets will get chop-suey'd and rewelded in due course. You could do as you describe, and it'll all align better, but you'll need some more isolation mounts to hold it against gravity.
#719 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 26 September 2017 - 04:46 AM
I take it back. Rotating it does have merit, just means work... but it'll be much neater if I do, it'll give me more room for my diffuser too. Ughh, don't you're hate that... more work!
#720 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 26 September 2017 - 07:21 PM
Exhaust path ended up being too short. Couldn't fit the required bends plus a flexpipe in there. So flipped the muffler around, and tilted it around 45deg. Body of the muffler actually sits better this way... and most importantly the lower curve of the muffler now forms a nice line for the diffuser.
Cat I'll run parallel to the muffler, so a little further away from the turbo outlet than planned. Hopefully still close enough to get hot enough for emissions.
    Bing (1)
