Project Fracas - 6Sp A20Nft
1268 replies to this topic
#61 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 18 January 2016 - 02:21 PM
Can't really comment on much of that as I haven't looked at in in detail. What I can say is that the flow out of the bonnet vents tends to slip around the sides of the windscreen/past the side mirrors, and over the hips at the back, it goes nowhere near the roof.
#62 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 18 January 2016 - 02:46 PM
Experience tells me otherwise, the air over the windscreen is warmer than ambient whereas, you got no thermal benefit from air slipping round the sides when the passenger windows were open. As I say, this is all circumstantial info. I am always intrigued by computer modelling and have no experience in using it / testing its validity... But given how sensitive all applications of maths is to the finest of details I just worry that any solid block modelling could be wildly inaccurate. If you are going to the trouble of trying to do it properly, then solid block modelling could be wasted time, if not done correctly. Again I am not trying to be a smart arse, just playing devils advocate.
#63 techieboy
Posted 18 January 2016 - 03:31 PM
Experience tells me otherwise. I think the model is spot on as regards the airflow out of the bonnet grilles flowing around the sides of the windscreen. You've only got to wind the windows half/two-thirds of the way down on a cold day, to get lovely warm air flowing straight into the car (and more effective than the heater usually :wacko:) from the front rad when moving.
#64 Doctor Ed
Doctor Ed
  • 1,188 posts
Would also be very speed dependent. I'm testing at relatively high velocity.
#65 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 21 January 2016 - 08:51 AM
About vortex generators. On the Evo 8 they have them on the back of roof and I cant believe this air will stay along the surface (rear window)?! I thought you used them exactly like on the speedster. If you have a cupe back you wont need them. Br, Per
Vortex generators help flow stay attached... to a surface. There is no surface on the standard rear clam, ie nothing to stay attached to. Vortex generators will do SFA. A longer roll bar cover (mini coupe back) would help somewhat, bringing the flow down a bit. A proper coupe back would be better.
#66 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 21 January 2016 - 09:16 AM
A vortex generator helps reduce flow separation from a surface, and improves the angle of attack of a surface before aerodynamic stall. It is exactly designed to help air stick to the rear window of an evo (how effective it is, I have no idea. On production evo's it's probably mostly a cosmetic thing). On wrc cars it def improves function of the wing element. On a vx coupe back, they would be of definite potential benefit. Sticking them on to the rollbar cover of a std vx on the other hand, will achieve SFA. As I said, no surface = no function (Only 'non aerodynamic stall' application I have seen is some company promoting them on the trailing edge of truck trailers. From memory they claim the induced vortices reduced drag behind the truck. I'm not even sure if that's true or just marketing spin).
Edited by ed.oates, 21 January 2016 - 09:17 AM.
#67 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 22 January 2016 - 06:55 PM
#68 2-20
2-20
  • 1,317 posts
Posted 22 January 2016 - 08:10 PM
http://bpi-us.com/pa...xgenerators.pdf
It show pressure distribution with and without the VG's
#69 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 January 2016 - 08:15 PM
Ok I believe you. I saw that video on youtube aswell, just havent got time to see it. Br, Per
#70 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 31 January 2016 - 02:00 PM
snatched up some parts for cheap...
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]Z22YH Zafira B 2.2L M32[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]1. 3,818[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]2. 2,158[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]3. 1,475[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]4. 1,067[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]5. 0,875[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]6. 0,744[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]R. 3,545[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]final diff ratio:[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]3,833[/color]
and one M62 with manifold...
#71 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 31 January 2016 - 02:01 PM
and one MBR 1" ARB
#72 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 02 February 2016 - 02:22 PM
I like your posts, my splitter and diffuser and wing do work... from now on fingers in my ears not listing :lol:
on a serious note, your info looks interesting and a good read. keep it up
Edited by Andrew aka Stuwy, 02 February 2016 - 02:38 PM.
#73 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 02 February 2016 - 09:13 PM
I quite like the panda scheme :) And style wise, the exige sport spoiler does match the lines of the car really nicely. What's the front splitter? (The one above the plywood part?)
#74 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 03 February 2016 - 01:08 PM
storm trooper :lol:
it was made by FLD on this forum. All CF
#75 Nev
Posted 04 February 2016 - 04:38 PM
Deffo get a low final drive in your gearbox or 5th gear will be useless apart from cruising, doubly so if you increase rolling rear wheel diameter size. This is one of my regrets from when I had the box open, as my car does 160 MPH in 4th gear alone, so 5th is wasted.
Edited by Nev, 04 February 2016 - 04:39 PM.
#76 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 05 February 2016 - 11:41 AM
the box i got is a 3.83
low as i could get with the short ratio gear set
#77 fezzasus
Posted 05 February 2016 - 03:42 PM
Looks like a nice project. Do you have all the gaskets you need for the supercharger kit? They aren't in the photo.
#78 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 05 February 2016 - 07:40 PM
Nope. Although to be fair gaskets are usually the last thing I buy as I'm screwing things together. They usually just get lost or bent if they sit around too long :) Just got offered a set of basically new nitron 46mm 3-ways with ex. reservoir and 550/700 springs for about half rrp. Still obscenely expensive, but oh so tempting. So tempting!
#79 smiley
Posted 05 February 2016 - 08:17 PM
Probably this set Ed?
http://forum.opel-sp...showtopic=36303
M63 gaskets will need to come from US, so don't wait to long with ordering.
#80 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 06 February 2016 - 03:56 AM
Thems the ones, just not the price :) A hefty chunk over my budget nonetheless, and I'm not 100% set on it. But tending towards 'just buy them'. You get a lot for your money, and they're a lot better shock than the things I was looking at around 1200-1500. Need an appropriate wife diversion... Hmmm
Edited by ed.oates, 06 February 2016 - 03:57 AM.
