Project Fracas - 6Sp A20Nft
#821
Posted 11 February 2018 - 05:24 PM
#822
Posted 11 February 2018 - 05:56 PM
#823
Posted 11 February 2018 - 05:57 PM
#824
#825
Posted 11 February 2018 - 06:04 PM
Here is a sample of engine movement with poly inserts.
I doubt 5mm will be enough.
#826
Posted 11 February 2018 - 06:10 PM
yes and no. the motor rocks, and from what i can see it rocks/rotates in such a way that the actuator rotates down, maintaining the gap to the subframe (kindve).
one way to find out!
#827
Posted 12 February 2018 - 10:30 AM
I thought about modifying / bodging a flattened cross over pipe like this one: http://www.illusiona...pics/engine.jpg Or, cutting out the mesh section and bonding back in just a slightly taller section
P.s. - Glad to see the engine in money shots
#828
Posted 12 February 2018 - 12:25 PM
#829
Posted 12 February 2018 - 01:03 PM
The pipe diameter after the turbo can be smaller because you move air under pressure and the important factor is the speed of the air through the pipe. Higher pressure equals to lower air speed. For around 320-340 HP, you should be able to get away with smaller diameter pipes, especially for that small part where you go over the engine. Obviously all bends and other obstructions add to the pressure difference of the whole system, but I wouldn't worry too much.
About that PWR barrel, do you have any data about it? The only thing I can find is 'good for xxx HP', which is kind of a nonsense statement. Or perhaps a better question: why this specific size and not bigger or smaller?
#830
Posted 12 February 2018 - 01:33 PM
- Tesla Roadster uprights (first car in space!)
Yup... Correct..
Looks like it's missing it's uprights and brake discs alright! (see the light through the wheel..)
Although I suspect most of the bits under the clam apart from the alu tub are missing from the 'car' anyway to keep the launch mass down..
#831
Posted 12 February 2018 - 03:45 PM
That's weird. The payload of the Falcon Heavy for that kind of orbit is over 10 tons. Tesla's are heavy, but not that heavy, so why remove parts? Normally they use water or concrete for these type of test flights. As it's Elon Musk's own roadster, all I can think of is that he was modding it and got tired of it. Sending it to the stars must have seemed like a good idea and he got the means. Or perhaps his wife, tired of him spending too much money on the car ... Did they ever check what's inside that suit?
#832
Posted 12 February 2018 - 04:01 PM
Rumour has it, one of his enemies.. I think the weight was probably selected to match the weight of a potential satellite being lined up to be launched, although the 'standard' Falcon rocket probably has that payload capacity alone..
#833
Posted 12 February 2018 - 05:32 PM
because thats the one that fell at my feet at the right time for the right price. its probably Overkill for my setup, but as i could make the space for it, theres certainly nothing wrong with having a slightly bigger core than the maths say is necessary.
im pretty sure dominik did some core pressure differential testing at some point (coincidently he has the same/similar PWR core) - he might chime in with what he measured (i cant remember).
#834
Posted 13 February 2018 - 05:52 AM
The pressure drop is ridiculously low - even when you max out that K04 turbo at 2.1 - 2.2bar.
It was like 0.1 bar or below.
And although the turbo is very inefficient in that high range - the PWR always keeps the IAT under ambient + 10°
So the maximum I ever reached was 46°C IAT on a hot 38°C day.
A better suited turbo would further drop the IAT,
Someone told me PWR rate them for a 0.25bar pressure drop.
So the rating of 600 hp equals to about 490 g/s or 380 litres /s
--> 0.25bar @ 490 g/s
To keep it easy for the simple chap they just tell you "600 hp"
#835
Posted 13 February 2018 - 06:45 AM
OK, thanks for the info. It is strange that they rate these things by pressure drop only. In that case, the best performer would be a straight pipe. It's far more interesting to have some information about the cooling capacity in combination with the pressure drop. But it looks like it's doing a decent job, 10C above ambient at a pressure drop of less than 100 mbar is very good.
#836
Posted 13 February 2018 - 08:38 AM
Just what I was told
Think you could get more detailed information from PWR.
Yep - best I measured so far.
Most front mount IC drop 0.2 to 0.3 bar if they are sized correctly.
Too small ones will create much more...
Think the Pro Alloy 7-row Chargecooler had about 0.3 bar (but I didn't measure that myself, just read it somewhere on a german forum)
#837
Posted 13 February 2018 - 02:42 PM
Answer from PWR Europe (they are quick!): HP rating is based on experience and it's always better to use an oversized intercooler. For about 400 HP, they recommend a 5"x10", rated at 500 HP. Which happens to be the one I was planning for. Only challenge is to find a place for it. Oh well, plenty of room on the outside of the car ...
#838
Posted 13 February 2018 - 04:42 PM
#839
Posted 13 February 2018 - 04:44 PM
#840
Posted 13 February 2018 - 05:03 PM
cut the firewall out! lol
if anyone ever wants to do this btw, ive got the design for my modified wall saved as CAD for cutting/folding
Bing (2)
