Project Fracas - 6Sp A20Nft
#1021
Posted 26 August 2018 - 08:33 AM
Of course it's your choice and the work you have done up to now is amazingly high quality and with efficient solutions, so I am certain it will look incredible when complete.
#1022
Posted 26 August 2018 - 08:57 AM
the main reason really i went this way was simply the aero benefit. there was so much chopping required of the VX clam, it became a silly proposition. i was doing sketches of how id mod the VX to what i wanted, and it looked progressively more and more like a GT3 anyway. doesn't matter, its just a skin. have an appropriate badge in mind for it too
Edited by Doctor Ed, 26 August 2018 - 09:04 AM.
#1023
Posted 26 August 2018 - 09:52 AM
anyone ever had a proper look at the difference in wheelbase between an exige and a VX??
based on paper specs the wheelbase is 230 vs 233cm (so 30mm difference) but ive read elsewhere 28mm, and for some reason ive got 27mm in my head.
eyeball-o-meter/stringline just now says 30mm, but before i cut sick with the angle grinder, thought id put it to the crowd!
also, way too soon to lose that last image to a new page... so repost...
Edited by Doctor Ed, 26 August 2018 - 09:53 AM.
#1024
Posted 26 August 2018 - 01:11 PM
I have found a couple of sources which say 29mm, but seen everything from 22 to 30 quoted by people.
#1025
Posted 26 August 2018 - 01:53 PM
After much stringlining and eyeballing, and embracing my inner plastic surgeon...
I went with a nice round 30mm stretch. Optically the 30mm works, and I think the post-cut stingline looks pretty damn close
#1026
Posted 27 August 2018 - 07:53 PM
#1027
Posted 03 September 2018 - 06:17 PM
#1028
Posted 05 September 2018 - 09:29 PM
Edited by Doctor Ed, 05 September 2018 - 09:30 PM.
#1029
Posted 06 September 2018 - 08:52 PM
Final offset at the back now ET-25 running on 10†and I think the tyre offset to the bodywork is spot on for purpose. so yeah, 120mm more rear track in total
now to get the body mounted properly
#1030
Posted 07 September 2018 - 09:06 AM
That's some spacers!
#1031
Posted 07 September 2018 - 09:31 AM
#1032
Posted 07 September 2018 - 10:46 AM
Spacers - yep they’re big, but they’re TÜV certified, so very reassuring.
#1033
Posted 07 September 2018 - 05:02 PM
#1034
Posted 07 September 2018 - 05:10 PM
How do the spacers affect the loads on the wheel bearings?
#1035
Posted 07 September 2018 - 06:47 PM
Edited by Doctor Ed, 07 September 2018 - 06:50 PM.
#1036
Posted 07 September 2018 - 06:54 PM
#1037
Posted 08 September 2018 - 08:22 AM
Focus RS frozen white, with black and carbon
#1038
Posted 08 September 2018 - 08:40 AM
That's some spacer! Mind you, how else would you fill those arches?
Deep-dish wheels with a -25ET would work too.
But those would likely need to be a custom jobbie and that tends to get expensive rapidly and possibly give TUV issues with not being a known 'road' wheel.
For something like these would do fine if you don't want spacers:
https://www.braid.es...wheels_p24.html
I know some Elise guys that ran GT3 clams used these types of wheels to get it wide enough.
Extremely light though...
#1039
Posted 08 September 2018 - 09:48 AM
and realistically, an ET-25 wheel will have pretty much the equivalent of that spacer simply integrated into the hub of the wheel casting/forging. i personally dont see any significant disadvantage of the spacer, particularly as its a tested and certified material/design. they dont sate the actualy material spec, but i wouldnt be surprised if its 7075 or similar.
deep dish and a big ET would also obviously work too, but as you say thats $$$$$$. ill get this (relatively cheap!) setup running and working for now, and if it makes sense in the future, i can always change the wheel setup - nothing is permanent/irreversible here
#1040
Posted 08 September 2018 - 09:59 AM
