Project Fracas - 6Sp A20Nft
#1061
Posted 28 September 2018 - 05:55 AM
#1062
Posted 28 September 2018 - 10:44 AM
#1063
Posted 30 September 2018 - 12:22 PM
And a lot of other similar things to your build. But getting to the point I'm 6foot 5./197cm and have raised my steering wheel and will be adjusting my pedals thanks to your tip and would love the measurements for your seat brackets. My mx5 is massive compared to the speedster 😂
#1064
Posted 30 September 2018 - 08:01 PM
sweden eh, LHD im assuming... ive got an extra set of the drivers seat bracket in LHD if you'd like, shoot me a PM. i could also send you the CAD file for laser cutting and folding, but you might as well get a pair already finished both the pedals extension and the column lift in combo with the seat got my 191cm in there. 197 is going to be interesting no matter which way you look at it!
#1065
Posted 30 September 2018 - 08:02 PM
meanwhile.. an uninteresting day of mostly invisible work. I'm working towards cutting out the rear panel between the taillights, along with the vents behind the rear wheels. Before doing so I figured it would be a smart idea to reinforce around these would-be cuts, before they become big floppy holes. Chopped mat blended in to chopped mat isn't really pic worthy
#1066
Posted 01 October 2018 - 07:29 PM
#1068
Posted 02 October 2018 - 07:02 AM
Scuse my ignorance, but how to the sanding discs attach and stay on the rubber mount?
#1069
Posted 02 October 2018 - 07:23 AM
#1070
Posted 02 October 2018 - 03:28 PM
machinist guy actually managed to machine the case hardened crown gear relatively easily. took a while till he got around to it, but job done! happy days. can get the good ratio gearbox rebuilt now with the 3.65 final drive and LSD
#1071
Posted 03 October 2018 - 05:40 PM
Wow, you've gone for 3.65 FD? I find it too long myself.
#1072
Posted 03 October 2018 - 07:39 PM
6sp box and lower individual gearing compared to a 5sp. top of 4th is 120mph. bang on perfect
heres the plot:
compare to your own graph. even taking rpm redline into account, you're still pushing longer ratios
http://www.vx220.org...ject/?p=1962551
Edited by Doctor Ed, 03 October 2018 - 07:48 PM.
#1073
Posted 04 October 2018 - 05:38 AM
Ah, are you using an F40?
#1074
Posted 04 October 2018 - 07:05 AM
#1075
Posted 09 October 2018 - 06:43 PM
#1076
Posted 09 October 2018 - 07:20 PM
Edited by Doctor Ed, 09 October 2018 - 07:27 PM.
#1077
Posted 10 October 2018 - 02:40 PM
part one, cut the guts out of the back of the clam (having previously reinforced the cut line)
cut line reinforced to 5mm, nice! doesnt flex around at all despite the massive hole
#1078
Posted 14 October 2018 - 04:44 PM
#1079
Posted 14 October 2018 - 04:53 PM
Do you think the plastic honeycomb grill will melt from the heat from the engine bay over time? Or is the plastic heat stable? It was a concern of mine and whether to use aluminium grill instead. It's looking really nice so far and the grill shape works well.
#1080
Posted 14 October 2018 - 04:55 PM
