Project Fracas - 6Sp A20Nft
1268 replies to this topic
#1081 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 14 October 2018 - 05:04 PM
Looking very good.
What are you going to do with the cutted roof scoop?
Br, Per
Edited by Aerodynamic, 14 October 2018 - 05:05 PM.
#1082 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 14 October 2018 - 07:31 PM
Turn the flow down to the front of the motor to cool ambient air around the intercooler and firewall
#1083 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 14 October 2018 - 07:36 PM
Do you think the plastic honeycomb grill will melt from the heat from the engine bay over time? Or is the plastic heat stable? It was a concern of mine and whether to use aluminium grill instead. It's looking really nice so far and the grill shape works well.
Im assuming it’s ABS which softens just over 100degC (and never truly melts). No idea of that spot in airflow would get that hot, and if, whether it would have significant effect on the form of that grill. Only one way to find out!
#1084 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 15 October 2018 - 06:58 AM
It's looking great well done.
The fibreglassing works have come out really well.
You must be pleased with the progress.
#1085 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 15 October 2018 - 10:52 AM
cheers mate :)
#1086 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 19 October 2018 - 09:50 PM
friday night, wife out for the evening, kids in bed... beers and bodywork time!! first pass with a glass reinforced polyester. was going to mix my own, but found a complete series of filler products from the same chemical company (Voss) who also make the resin ive been using for all the glasswork. so im assuming the filler bonding to base won't get any better than this :)
for a first session, and working quick with a fresh resin batch, the time flew. super happy. ive alway done bodywork in the dark with spot lamps, and today no exception. im feeling like neo. seeing the matrix with his fingertips. got some epics transitions blended, any issues of contour alignment have all but disappeared. will block it down tomorrow and use a fine filler as a second pass on sunday.
#1087 SteveA
SteveA
  • 9,156 posts
Posted 20 October 2018 - 10:08 AM
Are you planning to take a mould from the final finish?
#1088 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 20 October 2018 - 11:20 AM
The smart answer would be yes
We‘ll see :)
#1089 SteveA
SteveA
  • 9,156 posts
Posted 20 October 2018 - 11:55 AM
More work for sure but it will be worth it when some idiot rear ends you at a set of traffic lights.
#1090 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 20 October 2018 - 04:04 PM
hand blocked the filler today
fcuking goddamn bodywork
archlines
overview
water test
its not 100% there yet, but pretty nice. need to get the orbital out and get the big rear flat surface properly flat. theres a little too much undulation in there for me
#1091 Rosssco
Rosssco
  • 4,183 posts
Posted 21 October 2018 - 09:43 AM
Getting there!
Electrical / wiring question for you (just to change the subject) - With the E39a ECU you are using, does it use a feed for the VSS (Vehicle Speed Sensor), as I know some of the modern ECU's use torque management functionality which requires this (and is tricky on the Lotus chassis as they get a processed vehicle speed from the ABS system..)?
#1092 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 21 October 2018 - 11:00 AM
thats one for Dominik - i cant emphasise enough how much of an electronics hardware/software retard i am
#1093 Rosssco
Rosssco
  • 4,183 posts
Posted 21 October 2018 - 11:15 AM
Trust me, you are surely no more of an electronics retard than me Sir.. :lol:
I've just read sh*t on tinternet!
Edited by Rosssco, 21 October 2018 - 11:16 AM.
#1094 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 21 October 2018 - 02:14 PM
lol, ive tried. i can trouble shoot an analogue system ok (ie check voltages, following switching diagrams, use a scope to look for pulse phases etc) but the second things turn to 1's and 0's im out.
having some dramas with the rear deck - its a bit of a basin shaped compound concave curve, and theres ripples in it out of the mould (peak to peak around 10cm or so x3). tring to get them smooth in 2 planes with a single straight edge is a headfuck. after todays effort dry blocking it with a big sponge thing i think ive got it down to around 0.25mm from flat ... so really need to fine filler it. ill try and get something a bit bigger though along the lines of one of a spline before i do it though. heres one of the hipline curves and the sponge block i was using. the hips im 110% happy with at present. the big block really helped get the surface continuous. theres some ripples there, sure, we'll get there though. the trouble area is in the middle at the back, and is a PITA to take a photo of.
and little job #681 scratched off the list - cutting and mounting the rear lights into the clam. made a cardboard template based on the shape of the back of the lights, used this to transfer and mark the silhouette and mounting holes to the clam, and then cut sick with the dremel and flap wheel. starting to look like a car (albeit only from a very narrow rear quarter angle, lol)
Edited by Doctor Ed, 21 October 2018 - 02:17 PM.
#1095 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 21 October 2018 - 02:28 PM
edit.. dreadful photo... will need to take that one again. looked good on my phone!
Edited by Doctor Ed, 21 October 2018 - 02:29 PM.
#1096 Hopegreen
Hopegreen
  • 94 posts
Posted 21 October 2018 - 02:41 PM
Awesome work!
Can't wait to see what's going next!
#1097 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 21 October 2018 - 02:49 PM
big ass carbon diffuser ;)
thats the wooden frame slowly taking place under the car
#1098 BadCop
BadCop
  • 96 posts
Posted 22 October 2018 - 07:57 AM
:wub:  Love the widebody look
Getting there!
This is one of many points why you need the almighty "kopp racing" firmware on the E39A :)  :D
I programmed an unused analog input to acquire Vehicle speed.
Like in all modern setups the OEM E39A gets VSS via CAN  - which Lotus ABS does not support - plus you can not easily emulate the OE Astra ABS because of checksums etc.
So really the best and imho the only way is to get VSS directly wired.
The wire is already there because of the old Z22 and Z20 ECUs, so just plug it in the new ECU and let the KR firmware do its magic :)
#1099 Rosssco
Rosssco
  • 4,183 posts
Posted 22 October 2018 - 08:26 AM
Getting there!
Thanks for chiming in Dominik. Yeah, the (lack of) VSS seems to be an issue for anyone using the E39/39a , although some seem to have at least got around the issue using various hacks..
Unfortunately your magic only works with the A20NFT engine.. ;)
#1100 BadCop
BadCop
  • 96 posts
Posted 22 October 2018 - 08:56 AM
Yeah I think I know... -  the guys using the A20NFT for their airboats? :D
But on a car I'd highly recommend using VSS + TM on a car.
Even a racecar is so much better with the Torque Management on because the ECU knows your speed and calculates power demand and the sharpness of response.
For example when driving through the pit in first or second gear without TM and the throttle set to maximum response you look like an idiot riding a mental camel from the side :D
TM smoothes it out perfectly without inducing lag.
It gives you smooth load transition out of the 2nd / 3rd gear bends which means you can floor it at the apex, the throttle blade instantly goes WOT and then the boost comes in quickly but smoothly.
Not only A20NFT - they use the ECU from 1.0l 3-Cyl up to 7.0l Chevy stroker V8 :)
That is why I specialized on that E39A - because its super versatile and has built in high voltage converters for driving Direct Injection.
-.- somehow I cant copy the tables...
OK, here are just the US vehicles:
  2016 Buick Enclave Convenience Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick Enclave Leather Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick Enclave Premium Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick Enclave Premium Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Base Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Base Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Buick LaCrosse Base Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Leather Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Leather Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Buick LaCrosse Leather Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Premium Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Buick LaCrosse Premium Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Premium Sedan 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick LaCrosse Sport Touring Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Buick LaCrosse Sport Touring Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Buick Regal Base Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2016 Buick Regal Base Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Buick Regal GS Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2016 Buick Regal Premium Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2016 Buick Regal Premium Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated   2016 Buick Regal Sport Touring Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2016 Buick Verano Base Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Buick Verano Convenience Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Buick Verano CX Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Buick Verano CXL Sedan 4-Door 2.0L 2000CC 122Cu. In. l4 GAS DOHC Turbocharged   2016 Buick Verano Leather Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Buick Verano Premium Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 FLEX DOHC Turbocharged   2016 Buick Verano Sport Touring Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Cadillac SRX Base Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Cadillac SRX Luxury Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Cadillac SRX Luxury Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac SRX Performance Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Cadillac SRX Premium Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Cadillac SRX Premium Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Base Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Livery Hearse 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Livery Limousine 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Luxury Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Platinum Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Premium Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Cadillac XTS Vsport Platinum Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Turbocharged   2016 Cadillac XTS Vsport Premium Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Turbocharged   2016 Chevrolet Caprice PPV Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Chevrolet Caprice PPV Sedan 4-Door 6.0L 5967CC 364Cu. In. V8 FLEX OHV Naturally Aspirated   2016 Chevrolet Equinox L Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Equinox L Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LS Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Equinox LS Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LS Sport Utility 4-Door 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LT Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Equinox LT Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LT Sport Utility 4-Door 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LT Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Chevrolet Equinox LT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LTZ Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Equinox LTZ Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LTZ Sport Utility 4-Door 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Equinox LTZ Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Chevrolet Equinox LTZ Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Chevrolet Impala LS Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Impala LS Sedan 4-Door 3.6L 217Cu. In. V6 BI-FUEL DOHC Naturally Aspirated   2016 Chevrolet Impala LT Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Impala LT Sedan 4-Door 3.6L 217Cu. In. V6 BI-FUEL DOHC Naturally Aspirated   2016 Chevrolet Impala LT Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Chevrolet Impala LTZ Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 Chevrolet Impala LTZ Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2016 Chevrolet Malibu Limited LS Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Malibu Limited LT Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Malibu Limited LTZ Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2016 Chevrolet Traverse Base Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Chevrolet Traverse LS Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Chevrolet Traverse LT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 Chevrolet Traverse LTZ Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia Denali Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia Denali Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia SL Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia SLE Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia SLT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia SLT1 Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Acadia SLT2 Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Terrain Denali Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 GMC Terrain Denali Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 GMC Terrain Denali Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Terrain Denali Sport Utility 4-Door 3.6L 3600CC 220Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Terrain SL Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 GMC Terrain SL Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 GMC Terrain SLE Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 GMC Terrain SLE Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 GMC Terrain SLE Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Terrain SLT Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2016 GMC Terrain SLT Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2016 GMC Terrain SLT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2016 GMC Terrain SLT Sport Utility 4-Door 3.6L 3600CC 220Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Buick Enclave Convenience Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Buick Enclave Leather Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Buick Enclave Premium Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Buick Enclave Premium Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Buick LaCrosse Base Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated   2015 Buick LaCrosse Base Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Buick LaCrosse Leather Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated
  2015 Buick LaCrosse Leather Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Buick LaCrosse Premium Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Buick LaCrosse Premium Sedan 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Buick Regal Base Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Buick Regal Base Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Buick Regal GS Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Buick Regal Premium Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Buick Regal Premium Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated   2015 Buick Verano Base Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Buick Verano Convenience Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Buick Verano CX Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Buick Verano CXL Sedan 4-Door 2.0L 2000CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Buick Verano Leather Sedan 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Buick Verano Premium Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 FLEX DOHC Turbocharged   2015 Cadillac CTS Base Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Cadillac CTS Luxury Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Cadillac CTS Performance Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Cadillac CTS Premium Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Cadillac SRX Base Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Cadillac SRX Luxury Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated
  2015 Cadillac SRX Luxury Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac SRX Performance Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Cadillac SRX Premium Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Cadillac SRX Premium Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Base Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Livery Hearse 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Livery Limousine 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Luxury Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Platinum Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Premium Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Cadillac XTS Vsport Platinum Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Turbocharged   2015 Cadillac XTS Vsport Premium Sedan 4-Door 3.6L 217Cu. In. V6 GAS DOHC Turbocharged   2015 Chevrolet Camaro LS Coupe 2-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Camaro LT Convertible 2-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Camaro LT Coupe 2-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Camaro LT Coupe 2-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Caprice PPV Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Chevrolet Caprice PPV Sedan 4-Door 6.0L 5967CC 364Cu. In. V8 FLEX OHV Naturally Aspirated   2015 Chevrolet Captiva Sport LS Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Captiva Sport LS Sport Utility 4-Door 2.4L 2405CC 147Cu. In. l4 GAS DOHC Naturally Aspirated
  2015 Chevrolet Captiva Sport LT Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Captiva Sport LTZ Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox L Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox L Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Equinox LS Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox LS Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Equinox LT Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox LT Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Equinox LT Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox LT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Equinox LTZ Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox LTZ Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Equinox LTZ Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Chevrolet Equinox LTZ Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Impala LS Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Impala LS Sedan 4-Door 3.6L 217Cu. In. V6 BI-FUEL DOHC Naturally Aspirated   2015 Chevrolet Impala LT Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Impala LT Sedan 4-Door 3.6L 217Cu. In. V6 BI-FUEL DOHC Naturally Aspirated   2015 Chevrolet Impala LT Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Chevrolet Impala LTZ Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Impala LTZ Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 Chevrolet Malibu LS Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Malibu LT Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Chevrolet Malibu LT Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Malibu LT Sedan 4-Door 2.5L 2499CC 152Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Malibu LTZ Sedan 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged   2015 Chevrolet Malibu LTZ Sedan 4-Door 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated   2015 Chevrolet Traverse Base Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Traverse LS Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Traverse LT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 Chevrolet Traverse LTZ Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Acadia Denali Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Acadia Denali Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Acadia SLE Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Acadia SLT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Acadia SLT1 Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Acadia SLT2 Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Terrain Denali Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 GMC Terrain Denali Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 GMC Terrain Denali Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 GMC Terrain Denali Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Terrain Denali Sport Utility 4-Door 3.6L 3600CC 220Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Terrain SL Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 GMC Terrain SL Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 GMC Terrain SLE Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 GMC Terrain SLE Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 GMC Terrain SLE Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 GMC Terrain SLE Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Terrain SLT Sport Utility 4-Door 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated   2015 GMC Terrain SLT Sport Utility 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated   2015 GMC Terrain SLT Sport Utility 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2015 GMC Terrain SLT Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2015 GMC Terrain SLT Sport Utility 4-Door 3.6L 3600CC 220Cu. In. V6 GAS DOHC Naturally Aspirated   2014 Buick Enclave Convenience Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2014 Buick Enclave CXL Sport Utility 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated   2014 Buick Enclave Leather Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2014 Buick Enclave Premium Sport Utility 4-Door 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated   2014 Buick LaCrosse Base Sedan 4-Door 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated   2014 Buick LaCrosse Base Sedan 4-Door 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated   2014 Buick LaCrosse CXS Sedan 4-Door 3.6L 3564CC 217Cu. In. V6 GAS DOHC Naturally Aspirated
Edited by BadCop, 22 October 2018 - 09:06 AM.
    Bing (1)
