Br, Per
In any laminate its the outer layers that do the work. using a glass core is a way of adding thickness without costing a fortune. Might be this?
Posted 30 May 2019 - 05:46 PM
Posted 30 May 2019 - 07:07 PM
Posted 31 May 2019 - 08:43 AM
Posted 31 May 2019 - 08:46 AM
You'd use foam or honeycomb to include air. You need some sort of link between the skins.
Posted 31 May 2019 - 11:13 AM
Posted 31 May 2019 - 01:48 PM
Edited by Doctor Ed, 31 May 2019 - 01:55 PM.
Posted 31 May 2019 - 04:30 PM
I used 3d core in my undertray with solid carbon around the mounting holes. It gives a nice stiff laminate but it is quite heavy. If I were to make mine again I'd just use foam, or solid like you are doing.
Posted 01 June 2019 - 12:57 PM
Posted 01 June 2019 - 04:11 PM
Impressive work. I want to learn moulding carbon fibre.
Br, Per
Posted 01 June 2019 - 07:56 PM
Posted 02 June 2019 - 08:50 PM
Posted 03 June 2019 - 04:48 AM
Posted 03 June 2019 - 06:35 AM
Posted 03 June 2019 - 12:26 PM
flow testing is going to consist of smoke flares and early morning Autobahn flybys
Some DIY hints and tips for measuring Aero... guy is even a fellow Ozzie
Measuring car aerodynamic panel pressures https://youtu.be/OuSf3K6yuMc
Aerodynamic tuft testing of cars https://youtu.be/CsREhs9zZTQ
Posted 03 June 2019 - 08:17 PM
Edited by Doctor Ed, 03 June 2019 - 08:17 PM.
Posted 03 June 2019 - 09:06 PM
wow, Julian Edgar. Blokes a bit of a tugger, and has obviously been on a video making binge to push his new book. very 1990's but not entirely wrong either.
ha ha, fully agree
Posted 04 June 2019 - 11:40 AM
Posted 04 June 2019 - 09:04 PM
Posted 05 June 2019 - 06:40 PM
