Project Fracas - 6Sp A20Nft
#121
Posted 19 March 2016 - 08:51 PM
#122
Posted 19 March 2016 - 08:59 PM
Do you know what model-year car the Elise hoop is off of?
The reason I ask is that the early S2's (2001-2002) had so-called 'long tail' softtops and they have slightly different mounting points/tabs welded on the hoop and could not fit a hardtop.
The later cars (2003-onward) got the VX style 'short softtop' and also then got the hardtop option.
Not really a big issue, but if your hoop is from an early car you may need to move/change the welded brackets for the soft- and hardtop side-rails forward.
I expect you might need some small alterations on the VX rollbar-cover too here and there because of the smaller pipe diameter.
#123
Posted 19 March 2016 - 09:07 PM
Edited by ed.oates, 19 March 2016 - 09:11 PM.
#124
Posted 20 March 2016 - 12:14 PM
That's what they do with the official Lotus 'short roof conversion' kit they sell to change from the old long-tail to the current short-tail.
It has new brackets and a small spacer/jig that you basically bolt onto the old ones. Then weld the new ones onto the bar and grind off the old brackets afterwards.
Shape of the brackets is likely tied to the opening/shape in the rollbar cover which is a little different between the VX and Elises even though AFAIK the plastic receptacles for the side-bars on the soft and hardtops that are bolted onto these brackets are in the end the same.
#125
Posted 30 March 2016 - 03:17 PM
#126
Posted 30 March 2016 - 04:30 PM
Jeeze, such a major project, are you logging your hours ?!
#127
Posted 30 March 2016 - 04:35 PM
#128
Posted 30 March 2016 - 06:07 PM
Donor car arriving from the UK
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);][/color]
Edited by ed.oates, 30 March 2016 - 06:12 PM.
#129
Posted 30 March 2016 - 06:09 PM
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]Charcoal ATS DTC 7.5/9.0" x17" with 225/240 Toyo R1Rs[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]8.5kg and 8.8kg /rim respectively[/color]
Edited by ed.oates, 30 March 2016 - 06:13 PM.
#130
Posted 30 March 2016 - 06:14 PM
'new' less shitty looking clam to replace the completely FUBARd one
love the vinyl. not
Robins Splitter sidled up for a demo fitting to see where it all wants to sit
Edited by ed.oates, 30 March 2016 - 06:15 PM.
#131
Posted 30 March 2016 - 06:16 PM
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]Amongst other goodies... créme de la créme[/color]
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]46mm 3 ways... fcuked if I know how to tune 3 ways, guess I'll have to figure it out. #firstworldproblems[/color]
#132
Posted 30 March 2016 - 07:33 PM
#133
Posted 30 March 2016 - 07:44 PM
Are those the 3 ways from the German forum? Too much hassle for me, but was doubting a bit these were actual 46's as the helper platform looked more like the 40 NTR's?
#134
Posted 30 March 2016 - 07:52 PM
#135
Posted 30 March 2016 - 08:01 PM
#136
Posted 31 March 2016 - 05:37 AM
#137
Posted 31 March 2016 - 12:40 PM
Edited by ed.oates, 31 March 2016 - 12:42 PM.
#138
Posted 31 March 2016 - 09:37 PM
had to move the center console / shifter over a complete set of holes (note the RHD console surround, in the LHD setup), similarly, ive needed to shift the passenger seat over about 20mm (wheres theres no holes) so will have to whip out the rivnut gun and make some new mounts for it, but... long story short, it all fits.
Edited by ed.oates, 31 March 2016 - 09:41 PM.
#139
Posted 31 March 2016 - 09:45 PM
also reduces the throw (side to side) by about 20% (from 50mm down to 40mm lever arm change - needed for cable clearance) but im making the gearstick longer, and reducing the fore/aft gate throw a similar amount, so itll all feel quite balanced, albeit with a short-shifter snap to it
Edited by ed.oates, 31 March 2016 - 09:47 PM.
#140
Posted 31 March 2016 - 09:51 PM
8mm ply dummy splitter tray. still fiddling around with how best to integrate this with the Robin splitter, as well as the OEM clam and crashbox. i want to design it to be able to carry a heavy load, but also not completely destroy the front of the car if it decides to dig into the ground. not sure thats a possible compromise, but we'll see
Bing (2)
