Expected Voltage Post Cat O2 Sensor?
lambda o2
22 replies to this topic
#1 Bakazan
Bakazan
  • 232 posts
Posted 10 January 2016 - 06:56 PM
What is the expected voltage for the post cat O2 sensor?
I'm getting P0140 and P0141 error codes. Reading the sensor output on Torque Ap it is giving a steady reading of 0.2V raising when the engine is revved then dropping back to 0.2.
Does the EML throw a different code if it suspects a problem with the CAT itself?
At steady state the first one wangs up and down between 0 and 0.7/0.8V as expected.
#2 slindborg
Posted 10 January 2016 - 07:56 PM
Should switch 0.2 to 0.8 ish at a similar rate to the precat
#3 Bakazan
Bakazan
  • 232 posts
Posted 10 January 2016 - 08:54 PM
Ok, so the sensor is buggered, I just wanted to rule out that it might be something simple like an intermittent fault in the wiring.
Thanks for.your help.
#4 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 11 January 2016 - 08:25 AM
Continuity test the sensor.
#5 Bakazan
Bakazan
  • 232 posts
Posted 11 January 2016 - 01:46 PM
Across the the heater circuit? Which colour wires?
Thanks
#6 slindborg
Posted 11 January 2016 - 02:38 PM
white and white
#7 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 04:31 PM
Pre cat sensor switches between 0.10 and 0.80 mv
But post cat is used to check catalyst efficiency. with throttle steady 2000 rpm and engine fully warm the voltage should be in the range of 60-85mv steady reading with very few fluctuations.
easiest way is to use a diagnostic machine with both readings showing at once. if both match then i'm afraid its the catalyst thats burned out. usually caused by a misfire of some description ie coil packed up and driven for a length of time.
PM me if you need more help.
#8 slindborg
Posted 11 January 2016 - 04:37 PM
well the lambda cheaters shouldnt work in that case :P.... oh hang on they do :lol:
0.2 -> 0.8 ->0.2 changing every 3seconds.
#9 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 04:45 PM
Providing it doesn't switch at the same rate as pre-cat the ecu wont trigger cat efficiency errors.  and as they switch at 1 hertz and not 3 in your case all is good !!
#10 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 04:47 PM
Only exception would be wide band sensor and they arent used post cat.
Also 0.20mv is very lean on that engine would expect at least 0.60mv
Do you have an air leak somewhere ? or perhaps low fuel pressure etc ??
#11 slindborg
Posted 11 January 2016 - 04:49 PM
no WAY!!!!!!!
#12 slindborg
Posted 11 January 2016 - 04:51 PM
Oh and for reference, its 0.2V not mV ;)
#13 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 05:08 PM
0.200v     as the last digit isn't shown by most instruments     Millivolts !!!!!
  • mV, millivolt: 1/1,000 of a volt, a measure of electrical potential
#14 slindborg
Posted 11 January 2016 - 05:18 PM
so youre actually doing this....
You said 0.1 to 0.8 mV..... and its actually 0.1 to 0.8V..... mild difference. But no, lets cock it up a treat for the OP to try and diagnose something
#15 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 05:34 PM
You started it, I dont do ridicule !
#16 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 05:41 PM
What are your error code descriptions ??
#17 slindborg
Posted 11 January 2016 - 05:47 PM
I never quoted scaling, granted, but.... ah fcuk it.
#18 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 05:56 PM
Any way your error codes give it away, see below
[color=rgb(0,0,0);font-family:verdana, sans-serif;background-color:rgb(221,221,221);]P0140 - 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)[/color]
[color=rgb(0,0,0);font-family:verdana, sans-serif;background-color:rgb(221,221,221);]P0141 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)[/color]
Without taking a look i cant be sure but logic would say that either your wiring is causing trouble or your lambda is knackered, best way would be to use a multimeter and check the resistance between the two white wires on the post cat lambda plug.  Cant remember the exact resistance but perhaps sindborg could add that bit ??
#19 slindborg
Posted 11 January 2016 - 05:59 PM
nope, I dont want to be right wrong again.
#20 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2016 - 06:05 PM
Just make sure theres some resistance (12 Ohms seems to ring a bell but not 100%).
If you cant do the resistance check and the wiring looks fairly good ie no corrosion in the plug its a fair bet the sensor is knackerd.
Also tagged with one or more of these keywords: lambda, o2
