Expected Voltage Post Cat O2 Sensor?
lambda o2
22 replies to this topic
#21 Bakazan
Bakazan
  • 232 posts
Posted 11 January 2016 - 07:46 PM
Thanks both, I'll check the resistance/continuity across the white wires at the weekend.
I had a look at the wires and there was no obvious damage despite the nearside boot drain dumping water onto that cable.
#22 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 12 January 2016 - 06:23 AM
I found that the sensor wire had a break by using a multimeter to check for resistance. There was no resistance in the sensor so we felt the cable and found a 'lump'. Stripping it back clearly showed the break, so crimped and waterproofed it and hey presto resistance and no eml
#23 DarkAge
DarkAge
  • 36 posts
Posted 16 January 2016 - 11:32 AM
The downstream post cat O2 sensor should not be switching.
P0140 can also be a leak in the exhaust precat. I just had this on my polo a month back, was a crack in the flexi pipe.
More info here:
O2 Sensors
A/F Sensors (wideband O2 sensors)
Also tagged with one or more of these keywords: lambda, o2
