Looking good.
Do some more fuel learning, as the new injectors do not have to work so hard, and that needs to be learned. As for the 6600 to 7k, there are a lot of obdtuner people suffering from that. One of the biggest mysteries out there.
Well, if there is one graph showing an "OBD limited power" it is this one; due to you larger pulley the M62 charger keeps the same torque level well in the higher rpms, untill "something" at 6.6K drops torque and power off the cliff. And I see no mechanical reason that could cause that behavior...
Your power is so linear that I would set the rpm limit to 7K and see if the measured drop off also rises by 200rpm. (7K is a safe limit on stock cams and valve springs.)
And then, after the fuel learns, start playing with some ignition timing.
Edited by Exmantaa, 05 September 2016 - 11:16 PM.
