Zzperfomance Lsj Pulley System
243 replies to this topic
#141 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 08:48 AM
Strange that stuff you look for and can't find often turns up right after you ask for it on a public forum :)
Would be great if someone could verify that this actualy is the ECU relay in the boot
If so it would be the 42-134 from biltema.se that would work for me.
Anyone disagree?
Edited by Jocke_D, 20 May 2016 - 08:53 AM.
#142 smiley
Posted 20 May 2016 - 08:59 AM
Nope, spot on. I just verified on my spare:
#143 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 20 May 2016 - 09:07 AM
Anyone disagree?
Yep, those Dutchies know their bussines!!
Edited by tibby, 20 May 2016 - 09:09 AM.
#144 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 10:58 AM
Hopefully this will be a happy friday night :)
All swedes that read this I guess should take a note that Biltemas 42-134 will work (hopefully) as ECU relay :)
#145 techieboy
Posted 20 May 2016 - 11:00 AM
Just be sure it can handle the current. Might be worth looking at the wiring diagrams to see what current the cables are rated to.
#146 vocky
Posted 20 May 2016 - 11:16 AM
The relay shown in your fingers is not suitable to use instead of the brown ecu relay. Brown relay has two normally open circuits. The black relay has one normally open and one normally closed circuit.
#147 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 12:17 PM
Thanks. Just realized my mistake   :)
Will get another one after work.
One more time, this (Biltema 42-304) will do the trick (!?)     ==>  Posted Image
Will the current be ok though (2x15A) ???
Edited by Jocke_D, 20 May 2016 - 12:19 PM.
#148 vocky
Posted 20 May 2016 - 12:28 PM
That will work in the same way as the brown relay, just a slightly different way of doing it.
#149 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 02:35 PM
Yeah. Noticed that my relay will keep both outputs connected all the time and the Siemens one will keep them disconnected until the relay is pulled. Will this cause any problem?
#150 vocky
Posted 20 May 2016 - 03:38 PM
one side feeds the injectors + lambda sensors and the other side the fuel pump (via the fuel pump relay and fuel cut off switch)
I cannot really seem any harm in using the black relay instead, there is no real potential back feed in the circuits.
#151 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 06:13 PM
That's good news in two ways. First I can use it without having to worry if it can harm anything. Second this will probably mean that I'll get my fuel pump to prime :)
I'll probably get back online later asking why the starter won't turn over...
#152 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 08:54 PM
aaaaaaand I'm back...
With the new relay the pump primes as it should. The "test pump relay" function in opcom works just like I thought it would now.
However, the car won't turn over. Didn't have the time today to check again but yesterday I measured some 12V on the solenoid and the same on the starter motor itself when pressing the button. There seem to be some problem with the starter itself ? What to do to check/fix it?
#153 vocky
Posted 20 May 2016 - 08:56 PM
The yellow relay is the starter relay, so that is through best place to start looking
#154 Jocke_D
Jocke_D
  • 407 posts
Posted 20 May 2016 - 09:47 PM
But if there was something wrong with the yellow one I take it the starter solenoid wouldn't click when pressing the button?
I also wouldn't be able to measure any voltage on the starter when pressing the button
Also someone said earlier in the thread that his turned over but wouldn't start when there was a problem with the yellow one. Was that not correct?
I'm not questioning what you are saying I just like to understand why I'm doing stuff :)
#155 vocky
Posted 20 May 2016 - 10:11 PM
If you are getting 12v at the solenoid when pressing the starter button and 12v at the motor then it's either a bad earth between the gearbox and chassis or a duff starter motor.
#156 Jocke_D
Jocke_D
  • 407 posts
Posted 21 May 2016 - 07:00 AM
That was what I was thinking also. Was hoping for a "patent pending" solution I hadn't thought of.
Both seem kind of far fetched to me, I mean why should either have gone bad while the car was on jacks?
Will try to get the time today to investigate both :)
#157 Jocke_D
Jocke_D
  • 407 posts
Posted 23 May 2016 - 06:02 AM
ehemmmmm....
Removed the starter (that was a pita job from underneath) and got it on the bench. Seemed to work just fine.
Started to measure lots of stuff. Changed some connectors. Then realized that there was something strange going on with the voltage measurements (made some reference measurements) and finally I found that the ground screw on the gearbox was loose. "Someone" had removed it when he was looking for a good place to put the CC pump and not screwed it back completely. I had a serious chat with this "someone", fastened the screw and then it fired straight up :)
Idle was perfect from the start, everything seem fine.
Now I'll just finish the looms, fasten stuff where it needs to be fastened and hopefully I'm good to go.
A small question about obdtuner, I assume that all parameters are logged even though I'm only looking at some of them, right? There might be an issue with my MAP sensor that I want Peter to take a look at.
#158 smiley
Posted 23 May 2016 - 06:37 AM
Yes, when you activate logging, everything is logged.
(that's why it's going straight to the laptop, instead of ecu, as it can be a bit much)
#159 jim61
jim61
  • 384 posts
Posted 23 May 2016 - 07:33 PM
Followed your thread with great interest -fantastic you have sorted out the problem ! Had something quite similar and spent lots of time and effort barking up the wrong trees ,really proves the need to check & double check the basics. Enjoy your extra HP 😀
#160 OneYet
OneYet
  • 1,354 posts
Posted 24 May 2016 - 03:29 PM
Grattis från Huskvarna!!
