I remember reading that people are having good results with the EliseParts butyl tape.
I bought some Tiger seal to do the job a while ago - is this not up to the job then?
Nick
Posted 13 January 2016 - 02:33 PM
Nick
Posted 13 January 2016 - 02:44 PM
Search is my friend....
Is the latest view to stick in situ with double sided tape then use Tiger seal to seal?
Posted 13 January 2016 - 03:46 PM
Use the Elise Parts butyl tape.
Double sided tape shouldn't be used as it's not waterproof, neither should tiger seal - it makes the plastic brittle.
Edited by fezzasus, 13 January 2016 - 03:46 PM.
Posted 13 January 2016 - 07:03 PM
Posted 13 January 2016 - 08:29 PM
Posted 14 January 2016 - 06:37 AM
Edited by Singingwolf, 14 January 2016 - 06:39 AM.
Posted 14 January 2016 - 09:06 AM
Silicone wont bond to the ABS.
Tiger seal shjould be OK if the surfaces are correctly prepped. Try CT one power grab and bond. Feckers will never come off with that stuff.
Posted 14 January 2016 - 07:32 PM
With silicon type I mean the same format ... I used "bostik Poly Max crystal" l apologize for misleading informations.....Silicone wont bond to the ABS. Tiger seal shjould be OK if the surfaces are correctly prepped. Try CT one power grab and bond. Feckers will never come off with that stuff.
Edited by Singingwolf, 14 January 2016 - 07:33 PM.
Posted 14 January 2016 - 08:22 PM
Posted 14 January 2016 - 08:33 PM
I did my rear light with sikaflex. Left for a day and then replaced. However next day started to come away again. (It was a hot day though and I drove the next day). Sealed again and left clamped for 3 days. That was probably 2 years ago - been fine ever since.
Reading on here though more and more people seem to be recommending the butyl tape.
Posted 15 January 2016 - 05:53 PM
Posted 17 February 2017 - 12:27 PM
having trouble cleaning off the original sealant used on the rear light to cover , tricky getting temperature just right, 130-140'C , but then I noticed the reflector plastic was melting a bit
its a pain to get the surface really back to clean prep
