Posted 15 January 2016 - 12:17 PM
Posted 15 January 2016 - 12:19 PM
I really don't think it's an issue TBH, unless there's some other cooling system issue, which should be addressed first anyway.
Plus, perhaps it helps cold start up temps..
Posted 15 January 2016 - 12:56 PM
Just a thought, but is it worth insulating the pipe that goes under the exhaust manifold on the NA? Just wondering, as surely being Ally, it will suffer heat soak from the exhaust. Thinking of putting some ally tape around it to reflect the heat abit. Anyone got any experience of this?
Sounds sensible to me, especially as it will be easyish to do, well thought out insulation in an engine bay is always a good idea IMO.
Posted 15 January 2016 - 02:33 PM
The point is, its already heat soaked from all the hot coolant in it! Plus the coolant flow in that pipe is pretty high, so there's little time to significantly heat soak. The fact that it has no shielding from factory indicates this isn't really an issue..
Posted 15 January 2016 - 04:17 PM
Posted 15 January 2016 - 04:59 PM
Its the pipe between the thermostat and the water pump, so there's only decent flow when the coolant is up to a certain temperature and the thermostat opens.
Posted 15 January 2016 - 05:03 PM
Also tagged with one or more of these keywords: coolant
General Discussion →
VX220 Discussion →
Waterless CoolantStarted by royal_rg02 , 23 Oct 2014 ![]() |
VX220 Discussion →
Help With Rad/coolant IssueStarted by Qazax , 25 Nov 2012 ![]() |
VX220 Discussion →
Something Strange Is Going On........Started by MWS , 13 Aug 2012 ![]() |
The Market Place →
Car Parts For Sale →
Various Parts For Sale - Jonnyboy Hardtop, Soft Top, Lights, EtcStarted by Gazza75 , 20 Feb 2012 ![]() |
VX220 Discussion →
Got That Funny Coolant Smell... OffsStarted by Andrew aka Stuwy , 03 Dec 2011 ![]() |
