Ultimate Carbon Front Splitter
26 replies to this topic
#1 r2mlb
r2mlb
  • 772 posts
Posted 23 January 2016 - 07:08 PM
I didn't have many decent pictures previously, but after tinkering today managed to get some of the splitter on and off the car.
This is a full length carbon fibre splitter from Ultimate Carbon. The underside is made from a hybrid carbon/kevlar material to make it stronger yet slightly flexible. Finished in gloss lacquer.
They have 3 left remaining and in stock. Price is £225 including postage.
#2 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 23 January 2016 - 07:52 PM
Bad pics (in the dark garage) but this is the same splitter and how I attached it (and reinforced the lowest parts) I also covered the front in Helitape to minimise the chance of it cracking. Though it does flex more than I expected, the Kevlar I guess.
Personally I'm very pleased with it.
#3 Renny
Renny
  • 1,171 posts
Posted 23 January 2016 - 08:32 PM
Love your axle stand!!
#4 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 23 January 2016 - 09:57 PM
Boxes of paper are the best axle stands in the world. Plus work supply them, so free! :D
#5 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 24 January 2016 - 07:53 AM
I'm looking more at the bit off sawn off wood used as a spacer. :lol:
#6 mitm
mitm
  • 689 posts
Posted 24 January 2016 - 09:44 AM
F1 stylee...:ph34r:
#7 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 24 January 2016 - 10:14 AM
Not a spacer. It's there to add bracing to the lip. It's glued on to both the base and lip.
The bolt is right through the front clam so the wood acts as a giant washer to stop the bolt pulling through and also ensures the wood won't come off in an impact.
It looks (is) a bit crude, but should be very effective.
#8 fiveoclock
fiveoclock
  • 9,453 posts
Posted 24 January 2016 - 10:16 AM
You've got the grain in the wood going the wrong way for the forces that may be applied to the splitter
Edited by fiveoclock, 24 January 2016 - 10:17 AM.
#9 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 24 January 2016 - 10:22 AM
You know I just thought the same while uploading the pic. Still it should be a lot stronger than nothing.
#10 r2mlb
r2mlb
  • 772 posts
Posted 24 January 2016 - 11:43 AM
Just for clarity, the splitter doesn't come with blocks of wood. That's an optional extra ;)
#11 r2mlb
r2mlb
  • 772 posts
Posted 24 January 2016 - 05:41 PM
2 left remaining...
#12 oblomov
oblomov
    oblomov
  • 3,851 posts
  • Interests:Mumblers
Posted 25 January 2016 - 11:00 AM
My immediate reaction too.  For the price it looks insubstantial, and the fact you've needed to reinforce it would indicate that's true.  Also the profile is such that it doesn't look as if it will do much to serve its intended purpose?
Edited by oblomov, 25 January 2016 - 11:08 AM.
#13 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
  • Interests:Invasive Operations
Posted 25 January 2016 - 02:27 PM
You know that if you hadn't pointed it out then nobody would have noticed.
#14 sford
sford
  • 1,441 posts
Posted 25 January 2016 - 04:20 PM
The idea behind this splitter is it acts like an air damn, there was a picture of some of the test data somewhere from when Thorney developed it. Mine (one of FLD's) wasn't attached very well in the middle and would open like a mouth at speed. No fault of the manufacture process I might add. I put additional fasteners in it and all seems ok now. Whether the increase in drag is worth it I'll never know, I just like that it looks like it's supposed to be there and doesn't jut out enough to catch every little bump.
#15 chickendippers
chickendippers
  • 488 posts
Posted 25 January 2016 - 04:28 PM
What sort of height clearance is there between the bottom of the splitter and the ground? I know it'll depend on wheels, suspension etc. I'd like one, but not sure if it's too low for around my area/the speed mountain to get into work.
#16 r2mlb
r2mlb
  • 772 posts
Posted 25 January 2016 - 05:18 PM
I've just been and measured mine. The depth of the splitter (at the deepest point) is 50mm. The clearance I have in my garage (so flat surface) is around 65mm. To put into context my car is lowered on Nitron NTRs and sat on TDs. I hope that helps :D
#17 r2mlb
r2mlb
  • 772 posts
Posted 25 January 2016 - 05:23 PM
Better picture showing clearance...
#18 Pollet
Pollet
  • 11 posts
Posted 11 February 2016 - 11:57 PM
I'm interested in one of them. The postage included is for UK or could be to Europe too? Spain in my case. Thanks ;)
#19 r2mlb
r2mlb
  • 772 posts
Posted 12 February 2016 - 10:36 AM
Yes they can deliver to Spain. I've sent you a PM.
#20 r2mlb
r2mlb
  • 772 posts
Posted 28 February 2016 - 11:20 AM
Bump
