Turning Over Very Slowly.....
Posted 25 February 2016 - 01:23 PM
Posted 25 February 2016 - 02:00 PM
New battery. Did you check voltage under load?
Posted 25 February 2016 - 04:43 PM
Posted 25 February 2016 - 08:11 PM
Posted 25 February 2016 - 08:25 PM
If the battery is FUBAR it will drag down any other power source attached.
Posted 25 February 2016 - 08:29 PM
Posted 25 February 2016 - 08:45 PM
Posted 28 February 2016 - 05:07 PM
well I've finally had chance to look at it today.
The voltage on the battery was 12.2 and after 3hrs fast charge went up to 12.6 still the same issue... checked the connections on the starter which are all good! cranked the engine over by hand and the alternator isn't ceased. I have had a lead from the engine to the chassis. No change!!!
I did a measure of the Voltage on the starter when the button was pressed and that went down to nearly 8V not sure what I'm supposed to be seeing??
however now I've reconnected the battery the passenger indicators light up and stay on........not sure if thats a code for anything
Doing all this with a hangover is probably not my best idea!!
Posted 28 February 2016 - 09:32 PM
Posted 28 February 2016 - 09:47 PM
Its a knackered battery
Posted 28 February 2016 - 09:49 PM
The VX220s seem to need a lot of cranking force to start. I've used "knackered" VX220 batteries to jump Elises off before now.
Posted 28 February 2016 - 10:24 PM
Posted 29 February 2016 - 06:58 PM
so Halfords said the battery had 12.4 v and the condition was Ok but still replaced it for me just to make sure. I got home fitted it and still the same...
Next is to disconnect the coil pack and get a wire from the battery straight to the starter and see if its the starter, but its forecast crappy weather for the rest of the week and I can't manage to push it up the hill into my garage. this is starting to get on my tits..
any suggestions on what else I could check?
Posted 29 February 2016 - 06:59 PM
Starter motor on its way out?
Its only 4-6mths old so in theory it should be OK but its next on my check list
Posted 29 February 2016 - 07:44 PM
Check all high current connections between the starter motor and the battery. This includes earth connections as well as positive connections. What might appear a good connection, may in fact have corrosion on the connector surfaces. The metal connector surfaces should be shiny.
8 volts at the starter is a little low.
A high electrical current requires only a small electrical resistance to cause a large voltage drop. e.g. surface corrosion on a connector.
Edited by 909, 29 February 2016 - 07:48 PM.
Posted 01 March 2016 - 01:09 PM
Posted 01 March 2016 - 06:20 PM
Posted 01 March 2016 - 06:42 PM
update!!
got home tonight and connected a 25mm2 cable from the neg battery terminal to the gearbox as below hay presto starts perfectly.....thank fcuk for that. so something has gone tits with the cable somewhere. instead of spending hours finding whats wrong I might just run the new cable in or see if its just a small one to the chassis thats needed. not sure I can leave it as it is
Even the indicator has turned off!!
Anyway thanks for all your help and advice on this MUCH APPRECIATED
Posted 01 March 2016 - 06:57 PM
Posted 01 March 2016 - 07:40 PM
