Rear Chassis (To Suspension Mount) - Same As S2/toyota ?
14 replies to this topic
#1 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 01 March 2016 - 09:46 AM
Heya fellas,
just looking at what off-the-shelf cages are available... and cant get a straight answer...
would a cage for an S2/Toyota Chassis, and specifically the rear legs, fit a VX?
the rear legs have integrated suspension pickup support, so it'd need to be a 1:1 match in order to fit
thoughts?
#2 junks
junks
  • 675 posts
Posted 01 March 2016 - 10:13 AM
I'll have a Toyota subframe here soon Ed & will be able to see hem side by side but I did think the only difference between the two was the position & composition of the cross beam matey
#3 fiveoclock
fiveoclock
  • 9,453 posts
Posted 01 March 2016 - 10:57 AM
There are no cages available off the shelf. Safety devices wiill make one to order for around £1100. At this time of the year the lead time will probably be around 3 months. When I ordered mine at a quiet time ie. not just before the start of a race season, the lead time was 2 months.
#4 junks
junks
  • 675 posts
Posted 01 March 2016 - 12:23 PM
Yep just checked Ed & the damper mounts are further back on the VX (should have realised given the extended wheelbase over the Lotus) ;)
#5 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 01 March 2016 - 02:56 PM
yeah, i was hedging that way (re longer wheelbase) but was wondering if the shock still happened to sit in the same spot regardless.
obviously not... blöd
was looking at getting mine through a mob in Hungary... €1000
#6 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 01 March 2016 - 03:04 PM
phil, does the VX otherwise look the same as the Toyo?
ie... just get the guys to jig the same mount just 28mm (or whatever it is?) further back
#7 fiveoclock
fiveoclock
  • 9,453 posts
Posted 01 March 2016 - 03:06 PM
whats the car going to be used for? Will it be able to get approval here if used for racing. Do they replace the roll bar too, this is needed on the vx unlike an s2
#8 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 01 March 2016 - 03:40 PM
FIA certified And yep, been chopping the roll bar out of the sucker over the last 2 days... Totally shitful job, and still not finished...
#9 vocky
Posted 01 March 2016 - 04:08 PM
Joe found out the hard way that the S2 does not fit :ffs:  :ffs:
#10 fiveoclock
fiveoclock
  • 9,453 posts
Posted 01 March 2016 - 04:26 PM
I would imagine that when you have the middle feet lined up with the roll bar mounts (in the corner behind the seats) the front feet dont line up/reach the beam??
#11 vocky
Posted 01 March 2016 - 10:23 PM
It was the diagonal rear bars, miles out at the subframe
#12 The Batman
Posted 01 March 2016 - 10:30 PM
That was a bad day
#13 vocky
Posted 02 March 2016 - 08:31 AM
That was a bad day
I think we both realised, without saying a word, that it was the end of your vx :(
#14 Arno
Arno
  • 1,238 posts
Posted 02 March 2016 - 08:34 AM
Just a side-note.. That picture is of a very oddball car.
This looks like a Rover Elise S2 ali chassis (various attachments are for Rover-engine based ancillaries) that seems to have been chopped and different bits welded/attached onto to graft a toyota rear subframe onto it.. Perhaps for a race series where they wanted to keep an existing river-based chassis/car (perhaps to keep the OEM non-assisted brakes?) and fit a Toyota engine?
#15 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 02 March 2016 - 10:16 AM
no idea about that specific one, but the finished jigs for the cage are standard S2 toyota
wouldnt be a big step to adjust the jig for the longer step back to the vx shocks, but i suspect it would simpler to rock up with the chassis, and say - "here, make it fit"
whether i can be fcuked though, is the question. I dont need a 'speccd' cage, i just want something a bit better than what there (stupid goddamn cutouts in the bar?? wtf?!), plus throw in a diagonal, and a harness bar
    Google (1)
