Posted 18 March 2016 - 09:43 PM
Posted 18 March 2016 - 10:07 PM
Yep, I used the uBend clamp you pointed too on fbook and it's come loose, I assume it's stretched from big crap steel or something. Will try and modify it or get an OEM one once I'm home
Posted 18 March 2016 - 10:18 PM
Posted 18 March 2016 - 10:21 PM
IM not sure on vibration as it's striped to fudge.
I got flagged on a drive by at Bedford (na engine tubby backbox) then noticed just after that my backbox was free to move. It doesn't go any tighter so reckon it's stretched.
Posted 18 March 2016 - 10:36 PM
Posted 18 March 2016 - 10:38 PM
I've added poly inserts to the engine mounts to reduce engine movement and also tried with/without the post-cat hanger connected with the same results.
Funny. My situation got better after adding the postcat hanger.
I don't have rubber on my precat hanger though.
Posted 19 March 2016 - 08:16 AM
Posted 19 March 2016 - 08:19 AM
Despite the movement it seems to keep a good seal add the u pipe goes so far into the main box, so if be surprised if it contributed any extra noise.. Oem clamp looks like the way to go though.IM not sure on vibration as it's striped to fudge. I got flagged on a drive by at Bedford (na engine tubby backbox) then noticed just after that my backbox was free to move. It doesn't go any tighter so reckon it's stretched.
Posted 19 March 2016 - 12:15 PM
Posted 19 March 2016 - 02:58 PM
Posted 31 March 2016 - 06:47 PM
Ordered an OEM one. I have a tubby u bend and backbox but it's the same number for both.
It turned up but it's massive. Going by the numbers on it it's a 70mm clamp. In the right GM packet etc. How can they get that so wrong??
Posted 31 March 2016 - 07:02 PM
OK - saves me ordering from Vauxhall!
I think the fundamental issue is that the box is mounted too solidly. It needs to be able to move around a bit more so the stress isn't put on the clamp to stop the movement. Replacing the solid rubber blocks with something like this should do the trick:
http://www.amazon.co...st mount rubber
(Note - I have only spent 5 minutes googling for the kind of thing I'm looking for and in no way recommend the above part)
Posted 31 March 2016 - 08:16 PM
Posted 31 March 2016 - 09:21 PM
Thanks. Will be interested to know if the 55-59mm band clamps well!
Posted 31 March 2016 - 10:09 PM
Posted 14 July 2016 - 08:05 PM
Posted 14 July 2016 - 08:17 PM
The one from autovaux was way too big, and expensive.
So I just got a cheap ebay one. Just monitoring it at th minute although I've not used the car for a while.
Posted 14 July 2016 - 08:28 PM
Posted 14 July 2016 - 09:07 PM
Posted 15 July 2016 - 10:53 AM
Also tagged with one or more of these keywords: trumpet
The Market Place →
Miscellaneous →
For Sale: Haynes/autodata Manuals From The 80's And 90'sStarted by slindborg , 01 Feb 2015 trumpet |
General Discussion →
Off topic Chat →
Iphone Cheap VendorStarted by Stevie Dubyah , 02 Dec 2014 iphone, trumpet |
Off topic Chat →
Cheap Single Trip Euro Breakdown CoverStarted by slindborg , 07 Oct 2014 trumpet |
The Market Place →
Car Parts For Sale →
Vx220 Rear BadgeStarted by slindborg , 22 Jul 2014 trumpet |
The Market Place →
Bosch Charge Cooler Pumps - On EbayStarted by Captain Vimes , 24 Jun 2014 trumpet |
Bing (1)
