Hi all,
I'm looking for a bit of advice from any legal boffins on here please?
To cut a long story short, in February of this year I bought a forged engine for the VX. The engine hadn't been ran since all the new parts were installed so was in effect a fresh build. Issues with the engine were apparent immediately after fitting in early March, with a bad misfire, blue smoke, high oil consumption and when removing the plugs to make sure they were ok, high amounts of oil on top of pistons 1 & 3, as well as an oil leak from the crank oil seal.
I had hoped that the oil on pistons issues was just a case of the rings not bedding in properly but after doing less than 100 miles and using over a litre of oil, it was clear that this is not the case. The engine is now in pieces and we've identified many things wrong, for example:
1) Crank oil seal looks like its been installed with a pick-axe hence the oil leak from there.
2) Crank has been lightened with what looks like a grinder, and metal shards in the bottom of sump.
3) The "shoulders" of the crank where the rod sits have been machined which has left a sharp edge, causing burring on the rods from the crank.
4) Scoring and pitting in cylinders 2&3, looks as if before forging the engine may have been stored outside and this is possibly where the pistons rusted onto the bore as they're identical in terms of position.
5) Oil control rings on pistons 1 & 3 installed incorrectly which has caused the majority of the issues.
Not to mention other issues for example a couple of bolts missing, 4x tappets needing to replaced, a LOT of silicone used on the sump gaskets, despite new ones being used.
I have messaged the seller highlighting all of the issues to see if we can come to a reasonable solution for both parties, only to be told that everything was fine when he sold it and that the rings were installed "correctly", yet this is clearly not the case. I have dated evidence of when the engine was put into the VX and even have a video of first strike up. I've also got dated messages for the following couple of days, contacting some very well known engine builders in the Vauxhall scene to get second, third and fourth opinions of what the issue could be and all of us thought oil control rings which we have now proved to be true.
Usually in a situation like this I'd put it down to life experience and just shrug it off, however due to the cost involved I simply cannot do this. The engine cost nearly £2000, and I've had to pay for removal of the standard engine and installation of the new engine - which I knew I would have to pay anyway. But now I'm having to pay extra to have the engine out, stripped down, assessed and rebuilt properly with brand new parts , and then obviously reinstalled which as you can imagine isn't going to be cheap.
