Anyone Know Much About Rigid Plastic Sheets?
4 replies to this topic
#1 pete-r
pete-r
  • 2,771 posts
Posted 05 April 2016 - 09:06 PM
I know there are some folks on here with an engineering job/interest, I'm looking for some rigid plastic sheet, 1msq, but thin. 0.5-1mm thickness and credit card rigidity would be ideal Anyone know what and where I should be searching for a good price?
#2 PhilipTreeWalker
PhilipTreeWalker
  • 152 posts
Posted 05 April 2016 - 09:22 PM
I can ask tomorrow. We share a unit with a plastics company, they know lots about plastic things.
#3 pete-r
pete-r
  • 2,771 posts
Posted 05 April 2016 - 09:29 PM
Nice one dude!
#4 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 06 April 2016 - 08:13 AM
Largely depends on your intended application? Does it need to be easilly cuttable, paintable or impact resistant? Colour, UV / heat resistant? Most acrylic perspex and polycarbonates at that thickness and dimensions are either going to be very brittle or very flexible, I would imagine you would almost be able to double some back on themselves. You may be better sourcing a piece by buying a suitably sized picture frame rather than buying it from a supplier in sheet form as it is commonly used as a substitute glazing material. Would carbonfibre sheet be a viable option? Naturally it will cost 8 times the price but for stiffness at that thickness not much else would come close. You could go for a glass backed composite to save on cost. Something like Dibond may also be of use, that has a plastic core within a thin aluminium sandwich for increased rigidity. It's widely used for sign making and is quite easilly workable and versatile.
Edited by -Dab-of-Oppo-, 06 April 2016 - 08:17 AM.
#5 pete-r
pete-r
  • 2,771 posts
Posted 06 April 2016 - 11:46 AM
Hi. It's fit a thin flat set of door cards which will be wrapped. Want them cheap so no cf, and flex is OK but nothing to much so the wrap won't adhere. Finally I need to trim it with either a saw or carpet scissors and finish the edges with a sanding block so the aluminium one might be too stiff.
