Saab B207 Engine
best place for engine bits
25 replies to this topic
#1 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 06 April 2016 - 04:41 PM
Hi all
Wheres the best place in the UK  for bits such as
piston rings
stretch rod bolts
crank pulley bolt
cam bolts
stretch head bolts
Neo brothers just have gaskets
Martin S
#2 siztenboots
Posted 06 April 2016 - 04:43 PM
oh, really as bad as that then. part numbers would be a good place to start
#3 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 06 April 2016 - 04:51 PM
Following a leakdown test I was told the rings haven't bedded hence losing so much oil, so got to start again.
#4 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 06 April 2016 - 04:57 PM
and this was caused by ?
#5 chris_uk
Posted 06 April 2016 - 05:03 PM
Martin, if its come to this why dont you just bin the b207 and put a z22 back in?
#6 CHILL Gone DUTCH
Posted 06 April 2016 - 05:13 PM
After driving the 2.0 I must say they feel gutless and think Martin should go 2.2 but before you buy any parts get the bores checked
#7 The Batman
Posted 06 April 2016 - 05:16 PM
It will need reboring/honing anyway for new rings if you're doing it properly
#8 fiveoclock
fiveoclock
  • 9,453 posts
Posted 06 April 2016 - 05:44 PM
This, sell the saab for whatever you can get, bite the bullet and just buy a factory 2.2, shove it in and have another 8 years of enjoyment.
#9 Kieran McC
Kieran McC
  • 3,416 posts
Posted 06 April 2016 - 05:53 PM
Cut your losses Martin and go back to a 2.2 , Get back to enjoying the car over the summer.
#10 The Batman
Posted 06 April 2016 - 05:54 PM
Give ya a tenner for the Saab lump :D
#11 fezzasus
Posted 06 April 2016 - 05:55 PM
How on earth is going back to a Z22 going to be any cheaper now? if this was a bedding in procedure (which I'm not convinced about) it shouldn't matter what engine he's using.
#12 fezzasus
Posted 06 April 2016 - 06:04 PM
Martin, part numbers are same as Z22SE. Best approach is to go to a Vauxhall dealer and provide them your reg when asking for the parts.
#13 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 06 April 2016 - 06:17 PM
Are they exactly the same as the Z22SE! All the bits I need?
Are there better rings that could go in!
Martin S
#14 fiveoclock
fiveoclock
  • 9,453 posts
Posted 06 April 2016 - 06:23 PM
It's not about cheap, it's about getting tbe car back to how he likes it and use and enjoy it hence I said cut your losses. I may be wrong g but I don't think Martin is a 19 year old running it on a fiver.
#15 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 06 April 2016 - 06:36 PM
I've got pistons/ rings which covered 1000miles and are like new (sold as seen mind ;) ). Plus a new set of head bolts that I thought I'd lost before my engine build.
#16 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 06 April 2016 - 06:40 PM
Reboring no but honing yes to help them bed in properly.
#17 Zoobeef
Zoobeef
  • 11,103 posts
Posted 06 April 2016 - 06:43 PM
It'll be interesting to measure the ring gaps on the 2 bad cylinders to see if they differ from the other 2.
#18 Bargi
Bargi
  • 4,483 posts
Posted 06 April 2016 - 06:44 PM
Sutol is never going to use his motor, just swap it and sell the rest. Saab heads go for good money for z22se people looking to upgrade.
#19 fezzasus
Posted 06 April 2016 - 07:47 PM
not the point. Martin's had a cat failure from day 1 with this engine which likely caused the internal damage. He hasn't had a chance to see what it's like when everything is healthy.
#20 Exmantaa
Posted 06 April 2016 - 08:43 PM
Martin S
The B207 = GM LSJ = Z20NET; all basically the same engine block as the Z22SE (with a different crank throw and piston/rod height)
Bolts etc. are all the same. => http://www.speedster...gine/index.html
And as said; buy the Mahle/Perfect Circle rings
