Hi everybody.
I have an annoying issue that I got after having the car sleep over the winter.
When I now, happy with the spring coming and all, tryied to start the car, it didn't.
The issue is that there are no fuelpressure, and this is due to the ECU not firing the fuelpump.
I have checked the fuelpump, which works fine.
The relay and connectors have been refreshed and are fine.
the FCO are reset and works as it should.
There are power to the K18 fuel relay
If I short the relay, the fuelpump starts.
There are 12v on the relay coil.
No error codes found on the ODBII
BUT there are no signal from the ECU to activate the relay.
The ECU does not prime the motor on startup, nor does it activate the pump when trying to start.
The starter cranks the engine without starting.
What condition has to be met for the ECU to prime/fuel the engine?
What to check for?
Please help! I want to take the little tubby for a spin....
Btw - its a Z20LET (Turbo) from 2003.
br
Patrik
