V6 Alfa Busso Engined Vx
51 replies to this topic
#1 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 10:56 AM
Got a project in mind - grafting a V6 alfa engine into the back of a VX
Does anyone have the subframe width measurements to hand ?
Any advice or previous knowledge is welcome
Georgeous engine see below:
https://upload.wikim...166_3-11_v6.jpg
#2 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 10 May 2016 - 11:26 AM
why not go for the compound charged alpha engine?
#3 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 11:39 AM
Sorry do you mean supercharged ??   which car is fitted with that ?
The busso 2.5 v6 i was thinking about is 175hp standard and a sensible price to buy a full car with loom etc
#4 techieboy
Posted 10 May 2016 - 11:55 AM
Chuffing heavy, especially with an Alfa gearbox, if they'll even fit. thumbsdown
#5 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 12:26 PM
Bit of forum searching suggests the package is around [color=rgb(255,255,255);font-family:Verdana, Arial, Helvetica, sans-serif;background-color:rgb(39,39,39);]136 kg[/color]
Sound right ??
#6 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 12:42 PM
Correction engine is 170kg
Gearbox 42.99kg         213kg rounded up
So the middle ground between na and tubby.
#7 ginek
ginek
  • 119 posts
Posted 10 May 2016 - 12:50 PM
Lovely engine, I hope you'll take 3.2 version from the GTA models.
#8 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 12:56 PM
Also found this too
Measurement Value Comments Width across the heads 545mm Taken at the rear of the engine Width across the Cam belt pullies 565mm This is the widest point Length 570mm From the front of the crank pulley to the rear of the clutch cover. Note that the throttle assembly, flexible inlet pipe and air flow sensor will add considerably to this, but is all on top of the engine. Height 680mm Bottom of sump to the top of the plenum Weight of Flywheel 8.0 Kg
#9 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 10 May 2016 - 12:58 PM
Your not allowed to do a V6 conversion because mine will be the only one when its finished :lol:
#10 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 10 May 2016 - 01:25 PM
  Sorry do you mean supercharged ??   which car is fitted with that ?   The busso 2.5 v6 i was thinking about is 175hp standard and a sensible price to buy a full car with loom etc
  nope, but I was thinking of the VW engine (compound charging aka twin charging) http://www.volkswage...logy/petrol/tsi
#11 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 10 May 2016 - 01:28 PM
the 1.4 tsi engine has 160 bhp (they claim) so 10 less then your 2.5 v6 and as its boosted will have ample tuning potential
#12 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 01:33 PM
Which engine ??
#13 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 01:35 PM
Its about the sound as well as the horses !!
Think Ferrari sound versus one of those boring German box sounds
#14 Rosssco
Rosssco
  • 4,183 posts
Posted 10 May 2016 - 01:48 PM
If you just want a V6, then the older GM engines are much easier to install as then the gearbox, clutch, driveshafts etc. etc. are all there...   They aren't particularly impressive by many accounts, but easy enough to get +200bhp (3.0 and 3.2L engines). They weight 160-170Kg. https://en.wikipedia..._V6_engine#3.2
#15 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 02:20 PM
Hmm interesting idea you got me thinking now  thumbsup  thumbsup
#16 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 10 May 2016 - 02:27 PM
    Which engine ??
A28NET insignia vxr engine with vectra vxr F40 gearbox
#17 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 02:40 PM
    Which engine ??
Isnt that engine turbo'd ??
#18 siztenboots
Posted 10 May 2016 - 03:01 PM
yes, 2.8 turbo'd but same thing was also a LP1 Cadillac NA engine https://en.wikipedia...ture_engine#LP1
#19 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 May 2016 - 03:16 PM
puts my engine choice to shame !!
#20 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 10 May 2016 - 06:22 PM
3.0 s/c v6 tsfi 420bhp iirc with software, pulley, exhaust and intake Sounds like a v8 and was very impressed. Also very compact and s/c in the v 👍 Even in heavy s5 it went really well.....did I mention the sound 😎 DG
