The Yellow Starter Relay
144 replies to this topic
#1 smiley
Posted 17 May 2016 - 01:25 PM
This relay seems to be out of production.
Speedster/VX220 number A116M0032, and lotus number B116M0032F
(elise-shop says it's in backlog at lotus)
Has anybody ever peeled off that red sticker to see if there is a parts number under it?
Red sticker says it's from MetaSystem, but my gutt feeling says it's generic.
Anybody ever took it apart to find parts numbers?
Edited by smiley, 17 May 2016 - 01:38 PM.
#2 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 17 May 2016 - 01:31 PM
Got to be a vauxhall bit surely? Used be in the footwell in normal vauxhalls/opels next to the ECU when I were a lad. Can't imagine any reason it'd be entirely different.
#3 siztenboots
  • 26,613 posts
Posted 17 May 2016 - 01:33 PM
what is the relays logic table?
#4 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 17 May 2016 - 01:35 PM
I am however talking about the fuel pump relay in the boot. The yellow one.
#5 smiley
Posted 17 May 2016 - 01:39 PM
What do you mean by that?
The numbers on the pins?
#6 siztenboots
  • 26,613 posts
Posted 17 May 2016 - 01:43 PM
K18 brown , ecu
K24 yellow , starter motor  ( think its a typo on "K14" on the guide )
K16 grey , fuel pump
turbo has another 4th relay
all 3 grey bosch , apart from the Lotus special yellow one
#7 smiley
Posted 17 May 2016 - 01:52 PM
Edited by smiley, 17 May 2016 - 01:57 PM.
#8 siztenboots
  • 26,613 posts
Posted 17 May 2016 - 02:08 PM
just looking at the wiring diagram, there was a typo on the forum that labelled the yellow relay as K14 , wiring diagram says its K24.
pin 5 and 3 are switched by relay
pin 5 , BN , "205" FL4 40A
pin 3 , BNRD , Z20LET [ X4 BNRD , X34 BNRD , pin 50 M1 ]  or Z22SE [ X1 BNRD , pin 50 M1 ]
pin 4 , GN , "141" FB7 10A
pin 2 , BK , Ground
pin 6 , WHRD , pin 1 S124 , pin 2 S124 , BK Ground ]
pin 9 , WHBK , Ignition switch barrel via Z20LET [  pin 20 ECU X31 ] or Z22SE [ pin 9 ECU X21 ]
[font="Calibri;font-size:11pt;color:rgb(0,0,0);"]FL4 Main fuse Voltage distribution Engine[/font]
[color=rgb(0,0,0);font-family:Calibri;font-size:11pt;]FB7 Fuse – Engine[/color]
[font="Calibri;font-size:11pt;color:rgb(0,0,0);"]M1 Starter Start & Charging/Voltage distribution[/font]
[font="Calibri;font-size:11pt;color:rgb(0,0,0);"]S124 Switch - Starter button Start & Charging Voltage distribution[/font]
#9 techieboy
Posted 17 May 2016 - 02:14 PM
Fuel pump relay is the brown one.
But, I wish the yellow one was the same height as a normal relay. Would make life much easier to re-site them in a new waterproof relay holder.
#10 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 17 May 2016 - 02:22 PM
My bad, it's been a while. Surely the engine electrics are GM gear though?
#11 techieboy
Posted 17 May 2016 - 02:30 PM
Nah, this is definitely not a standard GM thing. Much more likely (especially given it's a Meta) to be part of an aftermarket alarm/immobiliser setup.
#12 smiley
That's the point. (@LY_scott)
It's so custom, that our version has metasystem labeling, and the lotus one has lotus labeling.
Key to find out here if it's just rebadging/stickering, or real custom work.
Edited by smiley, 17 May 2016 - 02:31 PM.
#13 techieboy
Posted 17 May 2016 - 02:55 PM
Nothing hidden behind the label on my spare:
#14 smiley
Posted 17 May 2016 - 03:21 PM
Thanks Techie.
Are you brave enough to remove the yellow container and peek inside?
#15 siztenboots
  • 26,613 posts
Posted 17 May 2016 - 03:58 PM
its pin 9 on the relay base which is the mystery one, but could easily be bypassed
#16 vocky
Posted 17 May 2016 - 04:02 PM
I rewired mine and use a grey relay instead, all the yellow relay does is stop the 'starter' button from working once the engine is running thumbsup
But you do need to remember not to push the button when the engine is running :P
#17 techieboy
Posted 17 May 2016 - 04:05 PM
Thanks Techie.
Tried. Bent terminal later. Not trying further. :beat:
#18 smiley
Posted 17 May 2016 - 04:27 PM
But the grey relay can be swapped as is, for an emergency to get back home? (without any rewiring?)
#19 smiley
Posted 17 May 2016 - 09:19 PM
speedster4fun kindly took 1 apart.
Edited by smiley, 17 May 2016 - 09:48 PM.
#20 techieboy
Posted 17 May 2016 - 09:26 PM
That definitely doesn't look like a normal relay. :unsure:
