The Yellow Starter Relay
144 replies to this topic
#21 smiley
Posted 12 June 2016 - 11:18 AM
I rewired mine and use a grey relay instead, all the yellow relay does is stop the 'starter' button from working once the engine is running thumbsup
But you do need to remember not to push the button when the engine is running :P
Do you have a description of your rewiring?
(as the first dutch car has now come to a complete stop, due to non availability of the yellow one)
Edited by smiley, 12 June 2016 - 11:20 AM.
#22 vocky
Posted 19 June 2016 - 08:17 PM
simple :)
Brown 2.5mm goes to pin 30
Brown/Red 2.5mm goes to pin 87
White/Red 0.5mm goes to pin 85
Green 0.5mm goes to pin 86
#23 smiley
Posted 19 June 2016 - 09:33 PM
Thanks Vocky,
More for emergency purpose, to create a workaround to get home if the yellow one is fooked, would be to
get direct juice to the starting engine, is to temporarily (untill engine runs) connect pin 30 brown, to pin 87 brown/red.
For the electrically impared under us, that is bracket sloth 1M and 2M from the yellow relay:
Edited by smiley, 19 June 2016 - 09:36 PM.
#24 ElizP987
ElizP987
  • 4,037 posts
Posted 20 June 2016 - 04:06 PM
We've noticed on a lot of cars this is a black relay not a yellow one
Same size and everything though and has a GM stamp
I have a couple if anyone needs one?
#25 Wolfstone
Wolfstone
  • 12,987 posts
Posted 20 June 2016 - 05:19 PM
Does it have a GM part number stamped on it Liz?
#26 Exmantaa
Posted 20 June 2016 - 07:02 PM
It should be a pretty standard start inhibitor relay, but never bothered to find a suitable replacement part
#27 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 18 July 2016 - 08:53 PM
Was looking for another relay on fleaBay and saw this: http://www.ebay.de/i...=item4ad4269ae7
#28 techieboy
Posted 18 July 2016 - 09:21 PM
Great find. Given it's made by Meta and they're Italian and do central locking, it makes perfect sense that it's an OEM part on a Fiat. thumbsup
#29 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 18 July 2016 - 09:25 PM
This is one of Liz's relays I got as a spare because I'm paranoid.
You will notice that there is a pin discrepancy over the original lotus part, but as this came off a car I guess it doesn't matter ?
#30 techieboy
Posted 18 July 2016 - 09:34 PM
Dunno. Depends on whether the relay holder is usually wired up for all 6 terminals on the relay. If it is, it might be a problem if your car is wired for the "standard" layout. Is your relay the size of the rest of the relays? If it is and it does work, that would be handy as I'd like to fit a new relay box to include the normal boot relays, the charge cooler relay, wideband relay and probably a water injection system relay and none of them can cope with the size of the yellow relay.
Edited by techieboy, 18 July 2016 - 09:37 PM.
#31 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 18 July 2016 - 09:39 PM
I would go and swap the relays out and test for you but with the National on sat....fvck that I'm touching nothing  :D
#32 techieboy
Posted 18 July 2016 - 09:41 PM
Very good call. :D
#33 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 18 July 2016 - 09:51 PM
Its an oversized relay like the original yellow one. Other spares shown for comparison.
#34 techieboy
#35 fezzasus
Posted 19 July 2016 - 07:36 AM
I've got both a black relay from Liz coming and a yellow relay as identified by Ed. I'll report back.
(what's the worst that can happen?)
Bigger issue for me is sourcing the brown relay - I eventually found mine on the ground next to my car, full of water. It's AMR1088 as used on the original defender and a TVR. Not easy to locate, suspect they'll become the next problem relay after the yellow one.
#36 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 19 July 2016 - 12:17 PM
Brown relay :
http://www.rimmerbro...Item--i-AMR1088
#37 CHILL Gone DUTCH
Posted 19 July 2016 - 12:48 PM
Fiat punto
Central locking relay
#38 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 19 July 2016 - 02:19 PM
Fiat punto Central locking relay
and does it work (as a starter relay) ?  :D
#39 smiley
Posted 19 July 2016 - 02:22 PM
Minor detail writestuff. Any yellow relay with 6 pins is now under suspicion.
#40 CHILL Gone DUTCH
Posted 19 July 2016 - 02:28 PM
