The Yellow Starter Relay
144 replies to this topic
#41 ElizP987
ElizP987
  • 4,037 posts
Posted 19 July 2016 - 07:09 PM
Does it have a GM part number stamped on it Liz?
Sorry Ken, only just seen this
Can see theres a pic below now :)
Several vx's we have had in have these black ones fitted instead of the yellow ones :)
#42 garyk220
garyk220
  • 3,035 posts
Posted 19 July 2016 - 08:32 PM
This is one of Liz's relays I got as a spare because I'm paranoid.
You will notice that there is a pin discrepancy over the original lotus part, but as this came off a car I guess it doesn't matter ?
Searching the GM parts number comes up with this description;
Module
OEM part number 90069864
Windshield wiper pulse control
Supplied for Pontiac, Opel and Vauxhall cars and fits 22 GM cars. But the Oemcats website does not list the cars.
Rather than a new starter inhibit relay, it looks like someone has fitted this as a replacement. Probably works fine but without the starter inhibit function.
#43 smiley
Posted 19 July 2016 - 08:59 PM
Bigger issue for me is sourcing the brown relay - I eventually found mine on the ground next to my car, full of water. It's AMR1088 as used on the original defender and a TVR. Not easy to locate, suspect they'll become the next problem relay after the yellow one.
Here's the other number that beliongs to the brown one.  V23134-M52-X186
#44 fezzasus
Posted 22 July 2016 - 07:22 AM
Module
It's the VX wiper relay, which I guess is good news for anyone stuck with a broken yellow relay, but makes me much less enthusiastic to fit it to my car.
http://www.vx220.org...stion/?p=545144
Edited by fezzasus, 22 July 2016 - 07:25 AM.
#45 ElizP987
ElizP987
  • 4,037 posts
Posted 22 July 2016 - 08:13 AM
Hi guys
sorry but I've caused a bit of a mix-up here, a relay we had in while ago was black and was in the position of the yellow one. I wish now I had made a note of the details on it
We took another off a loom recently and assumed this had occurred again, but on closer inspection, the pins are in a slightly different position, and I think now it was took from the wrong plug, as the loom was off the car,
Sorry for any confusion mix-up :(
#46 vocky
Posted 22 July 2016 - 08:40 AM
Hi guys
I am so glad you wrote that because the wiring diagram states that the missing pin is actually for the starter button wire :mellow:
#47 smiley
Posted 22 July 2016 - 09:09 AM
So can still be used in an emergecy situation to get back home without rewiring?
#48 techieboy
Posted 22 July 2016 - 09:10 AM
I can't see how, if it bypasses the starter button.
#49 smiley
Posted 22 July 2016 - 09:15 AM
I thought is was for failsafe pressing while engine is running, but if it bypasses it completely, then indeed useless.
Anyone got the fiat one in yet, and tried it?
#50 techieboy
Posted 22 July 2016 - 09:21 AM
Mine apparently left Warsaw last night en-route to the UK. No idea how quickly it'll get here but I probably wont even bother trying it though as I'm 100% confident it'll be the right thing.
#51 fezzasus
Posted 22 July 2016 - 09:41 AM
I'll be testing mine as I'm currently running on borrowed relays.
Also have a B116xxx coded part from Lotus but this is on backorder.
#52 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 25 July 2016 - 03:16 PM
This relay seems to be out of production.
Speedster/VX220 number A116M0032, and lotus number B116M0032F
(elise-shop says it's in backlog at lotus)
Has anybody ever peeled off that red sticker to see if there is a parts number under it?
Red sticker says it's from MetaSystem, but my gutt feeling says it's generic.
Anybody ever took it apart to find parts numbers?
Still available to purchase from Vauxhall  thumbsup
VX - 9197914
META A116M0032 (Yellow)
£56+VAT
1 in stock in the UK, 2 in Germany.
#53 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 26 July 2016 - 06:31 AM
Ouch
#54 techieboy
Posted 27 July 2016 - 12:22 PM
Finally turned up and looks exactly the same (other than some OEM markings moulded into the top of it). Terminals and terminal labels all exactly the same as our relay.
Old on the left, new on the right.
#55 smiley
Posted 27 July 2016 - 12:37 PM
One of the dutch opened his fiat one.
Not identical.
You feel brave enough to try it Techie?
#56 fezzasus
Posted 27 July 2016 - 01:08 PM
Bugger. At this rate i'm going to have to start soldering the surface mounted components on the original yellow relay
#57 fezzasus
Posted 27 July 2016 - 01:18 PM
However there have been a couple of different versions of the start inhibit relay;
Version 1 (link -http://www.vx220.org...r-relay-needed/) :
Posted ImagePosted Image
Version 2 (link -http://www.vx220.org...-starter-relay/ ) :
#58 techieboy
Posted 27 July 2016 - 01:35 PM
Fcuk it. I'm looking more and more doubtful for Zandvoort anyway. If it totals the electric system, it won't be that big a problem.
#59 techieboy
Posted 27 July 2016 - 01:41 PM
Oh well. The car no longer works. Something has blown. Now I be fcuked. :(
#60 smiley
Posted 27 July 2016 - 01:43 PM
Oh, sh*t.
Smel of burning wires, or just a fuse?
