The Yellow Starter Relay
144 replies to this topic
#81 smiley
Posted 22 October 2017 - 10:07 PM
There are a few Sheldon Coopers in Holland working on a reproduction.
Should be a one on one replacement when finished.
Will update here when it´s available. (no release date set. This is just an fyi)
NO LIST !! :happy:
#82 The Batman
Posted 22 October 2017 - 11:44 PM
1. the batman
#83 smiley
Posted 05 December 2017 - 10:39 PM
Product ready. Testing started.
#84 CHILL Gone DUTCH
Posted 05 December 2017 - 10:44 PM
thumbs up
can we make a list yet
#85 smiley
Posted 05 December 2017 - 10:55 PM
Not up to me.
As soon as testing is done and pricing is known, i will update this topic.
This is the creator for those who can't wait to get their little grubby hands on one.
http://www.vx220.org...hard-hoogeveen/
Edited by smiley, 05 December 2017 - 10:59 PM.
#86 S. gonzales
S. gonzales
  • 26 posts
Posted 12 December 2017 - 11:47 AM
Now there is👍 See this link: https://www.speedste...=121674#p121667
#87 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 12 December 2017 - 01:04 PM
Brilliant that someone has managed to make these but I personally think its expensive for what there asking for it. Lotus was bad enough but these are nearly 4 times the price of lotus part.
#88 Richard Hoogeveen
Richard Hoogeveen
  • 73 posts
Posted 12 December 2017 - 05:07 PM
I won't deny that the price is "high". Actually it is rather cheap for handmade products like this. It took many hours to come this replacement relay and even programming/ building/preparing/testing one takes around 2 hours in the current layout. It is not my intension to get rich from this, but to help out others to keep their car running. It has to cover some of the costs and time it takes from me. And it must be fun to built these.... as long as I have fun there will be new stock. Verstuurd vanaf mijn SM-N910F met Tapatalk
#89 slindborg
Posted 12 December 2017 - 05:13 PM
I'd say that was cheap/great value for a diy answer to a problem that had no answer... Nice work Richard.
#90 CHILL Gone DUTCH
Posted 12 December 2017 - 05:37 PM
I agree cheap if you have a car that won't start
#91 smiley
Posted 12 December 2017 - 07:02 PM
For those not into our relays, the grey and brown one are from a range rover, and p*ss cheap to come at.
The yellow one is a custom one for our vx/speedster and the S2 also i believe. The yellow one was the most expensive one of the set. https://www.ersatzte...14::231752.html
It has been out of stock for over a year now. :dry: Either rewire your setup for it to take a grey one (Ask Vocky), and tell your passenger never to touch the start button while the engine is running, or get this one.
Edited by smiley, 12 December 2017 - 07:03 PM.
#92 Ivor
Ivor
  • 2,176 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 12 December 2017 - 09:11 PM
You have to say top effort that man! By accident I have a spare, best I put it in a glass case...
#93 C8RKH
C8RKH
  • 797 posts
Posted 13 December 2017 - 09:12 AM
I agree re top effort. Thanks for doing this Richard and hopefully your work will keep many VX/Speedsters on the go for years to come.
To those that are remarking re the price - it's funny, but in these days of mass produced cheapness I think people have truly forgotten just how much time, effort, skill, and perseverance is needed to make something.like this from scratch.
If there is any stock left after xmas I'm buying one, just in case, as stuff like this will  be harder and harder to get and will be essential to keep the cars going.
Thanks for this Richard. Top job.
#94 chris_uk
Posted 13 December 2017 - 10:55 AM
I have 4 originals in a draw at home, just in case.. :)
#95 hairy
hairy
    Moonlander
  • 6,032 posts
Posted 13 December 2017 - 07:25 PM
Crumbs, these are going up in price like bitcoins!
#96 vocky
Posted 14 December 2017 - 08:40 AM
Congrats on reproducing them :D
ps: bespoke components are always going to be more expensive than mass produced parts
pps: I prefer the rewire and standard relay approach :P
#97 harboged
harboged
  • 392 posts
Posted 14 December 2017 - 09:38 AM
Vocky, do you know if the ignition barrel has what's needed to connect an extra wire to it and make it work as a "normal" ignition lock? That way one could get rid of the stupid starter button and start the engine with the key instead, and also replace the troublesome yellow relay with a standard starter relay (like you seem to have done).
#98 vocky
Posted 14 December 2017 - 11:15 AM
the ignition switch is a standard Corsa B item. On the vx220 / speedster there is no wiring for the 'start' position.
The starter button is wired as a 'negative' and the ignition switch is a 'positive', so you would need to add another relay.
A simple circuit, connect the original starter button wires to 30 and 87, use the negative wire to also connect to 85 (one of the two wires will be a solid negative) and then run the wire from 86 to the ignition switch 'start' position.
You would also have to rewire the yellow relay base to accept a grey relay
#99 harboged
harboged
  • 392 posts
Posted 14 December 2017 - 04:57 PM
the ignition switch is a standard Corsa B item. On the vx220 / speedster there is no wiring for the 'start' position.   The starter button is wired as a 'negative' and the ignition switch is a 'positive', so you would need to add another relay.   A simple circuit, connect the original starter button wires to 30 and 87, use the negative wire to also connect to 85 (one of the two wires will be a solid negative) and then run the wire from 86 to the ignition switch 'start' position.   You would also have to rewire the yellow relay base to accept a grey relay
Alright, thank you very much! :)
#100 VampireTigger
VampireTigger
  • 1 posts
Posted 23 January 2018 - 12:00 PM
Hello, my name is Adrian. I work for Bell & Colvill who operate the DeRoure web site.
We've been trying to get these relays for some of you guys for some time now but they have been on back order for ages. For those who did not know, Elise-Shop bought from Bell & Colvill until they switched to direct supply from Lotus.
I've tried getting in contact with Meta but without much luck so far, Lotus are prepared to carry a stock of these relays if I find somewhere for them to purchase them from.
Thanks
