Motronic Me1.5.5 Pinouts And Vx Looms
Posted 18 May 2016 - 02:37 PM
2x 64-way connectors , BMK 0.6 terminals ( https://www.bosch-co...earch?q=bmk 0.6 )
Systems VX220 loom X31 - Engine Z20LET
Components
pin 21, pin 54, pin 22, pin 4, pin 37, common pin 5 B19 Sensor - Pedal position -> X3
pin 23, pin 53, common pin 5 B110 Sensor - Atmospheric pressure
pin 51 FB20 -> X2
pin 18 FB8 -> X3 #VT
pin 20 STA "111"-INS "733" -> X2
pin 35 INS "718" -> X2 #GNBU = PWM? Coolant sensor signal for dashboard LCD
pin 13 INS "743" -> X3 #BNBU
pin 57 SLS "428" -> X2
pin 25 SLS "429" -> X2
pin 8 CLS "439" -> X2
pin 29 MK "1143" -> X2 -> ground control for K13 rad fan relay
pin 45 Z20LET "944" K82 pin 4 Relay - Pump, coolant additional M55 - -> X3 #VTOG
pin 59 WEG "1243" - Vehicle speed signal (ABS) - -> X3 #YEGY
pin 2 IMO "1433" -> X3 #WHYE
pin 19 K18 pin 4 Relay - Engine control unit -> X2
pin 49-33-17 K18 pin 3 Relay - Engine control unit -> X2 (p17 -> X33)
pin 62 K16 pin 4 Relay - Fuel pump -> X2
pin11 optional canbus
pin32 optional canbus
Systems VX220 loom X32 - Engine Z20LET
Components
pin 45 common shield, common "932", pin 49, pin 25+8 B117 Sensor - Oxygen, mixture control, heated
pin 45 common shield, common "932", pin 17, pin 41+57 B118 Sensor - Oxygen, catalytic converter check
common "932", pin 35 Y8 Solenoid valve - Boost pressure regulation
pin 9 common, pin 7 common, "932" common, pin 6 B46 Air mass meter
pin 9 common, pin 7 common, pin 22, pin 55 B21 Sensor - Absolute pressure, intake manifold
pin 7 common, pin 7+36, pin 45 common shield B35 Sensor - Camshaft
pin 45 common shield, pin 42 #GYBK , pin 10 #GYRD B34 Impulse sensor - Crankshaft
pin 9 common, pin 38 B61 Sensor - Coolant temperature (gauge)
pin 15, pin 32, pin 31, pin 16 T1 Ignition coil - Direct ignition
C1 Condensor - Ignition coil
pin 21+37 B30 Sensor - Knock control 1
pin 11-43, pin 28-60, pin 39, pin 56, pin 23, pin 58 Y11 Throttle valve - Positioner
pin 50 Y2 Actuator - Recirculation
pin 31, X31 pin 3 common Y9.1 Injection valve - Cylinder 1
pin 18, X31 pin 3 common Y9.2 Injection valve - Cylinder 2
pin 2, X31 pin 3 common Y9.3 Injection valve - Cylinder 3
pin 34, X31 pin 3 common Y9.4 Injection valve - Cylinder 4
pin 33, X33 pin 6-"932" common Y5 Solenoid valve - Tank ventilation
info: pin x+y = means pins x and y are in a shielded cable
pin x-y = means pins x and y are connected
Abbreviations
INS Instrument MKM Engine cooling module
CLS Clutch switch SLS Stop lamp switch
TC Traction control WEG Vehicle speed signal
ESP Electronic stability program
#WHYE - wiring WhiteYellow
updated the loom X2 and X3 connector for X31 ecu plug
Thanks to Mike for his excellent compiled wiring diagram PDF
Posted 25 January 2017 - 12:25 PM
I seem to have misplaced part of my x31 ecu plug loom, but took some pictures b6d (starter motor, alternator, main chassis earth, knock sensor)
ECU X31 bottom (with atmo p sensor) , X32 top
b6d loom
k6x loom - ecu X32 plug
Posted 25 January 2017 - 07:33 PM
Do you need any photos of the X31 loom or any of the plugs? Mine is in a box upstairs at the moment.
Posted 27 January 2017 - 07:15 AM
Yes please they are a real pain to photo on the car in situ Need to confirm colour of x2 x3 plugsDo you need any photos of the X31 loom or any of the plugs? Mine is in a box upstairs at the moment.
Posted 27 January 2017 - 09:45 PM
OK no problem, will get some photos at the weekend. PM me an email address and I will send them over.
Posted 28 January 2017 - 08:06 AM
details
Posted 28 January 2017 - 03:06 PM
Zip file with several photos and a list of the wiring colours on the X2 and X3 plugs sent.
Posted 03 February 2017 - 11:29 AM
ecu plug details
Posted 04 December 2017 - 08:39 AM
I see the ecu pictures have gone, thats helpful
Posted 04 December 2017 - 12:14 PM
tvxr ecu plugs
Atmospheric barometer sensor plug , x31 left , x32 right , in situ . Earth wire hiding behind.
Security bolt and bracket drilling out
The 3rd ecu is just my spare with the K6X label
Posted 17 January 2018 - 05:22 PM
Posted 10 February 2018 - 05:12 PM
