For whatever reason you have been repeating my data, info, whatever you want to call it without mention of where it came from, since the day we proved it worked.
Before that you told us we were wrong. I pulled you in private and you said sorry but continued anyway.
All the stuff you said about me not sharing, everything in this thread of any use I already said, the only thing I said I would not do it post a specific spec for a car as it's far too diverse, easier for me to keep each person in his own PM so I and others don't get confused with what car I specified what for.
I spec slightly diff to aquamist tables because the positions I use, are so much more efficient than the usual "easy" route (in the intake or with the SC spacer) these require a lot more water.
All I can say is it works, very well indeed. If you want to try your own things go ahead, my issue is with you discrediting me, I worked very hard on this when lots of people were very negative or at least doubters. Just as well I ignored it all, and Neil for that matter as you were telling him not to do it. Credit to Neil for having the spirit to try it and thanks for your trust Neil.
And now WMI is another option that is not viewed in the same way it used to be.
Edited by Crabash, 02 July 2016 - 07:31 PM.
