Water Injection
513 replies to this topic
#281 chris_uk
Posted 07 September 2016 - 11:17 AM
why wouldn't you just add the non return valve in regardless of where the jets are.. seems like a silly thing to leave off.
#282 smiley
Posted 07 September 2016 - 11:18 AM
What are the dimensions of that pump? (as i had the same idea for location)
#283 CHILL Gone DUTCH
Posted 07 September 2016 - 11:22 AM
#284 CHILL Gone DUTCH
Posted 07 September 2016 - 11:35 AM
there is a recess higher up behind the battery ( if the euro cars are the same ) which backs on to the holes in the footwell in our case passenger side
so there might be a option there
#285 CHILL Gone DUTCH
Posted 07 September 2016 - 11:36 AM
or could get a smaller battery
#286 CHILL Gone DUTCH
Posted 07 September 2016 - 11:51 AM
when are you going to show us your install, you finished weeks ago ??
#287 CHILL Gone DUTCH
Posted 07 September 2016 - 12:29 PM
Should be able to mount it on the back side of this plate
But I require so one to pu nuts and washer on it for me while I'm holding it
#288 The Batman
Posted 07 September 2016 - 12:32 PM
Kids leave school in a couple of hours Or George is probably at home
#289 CHILL Gone DUTCH
Posted 07 September 2016 - 12:43 PM
So it will be mounted on the back side of here
Behind the battery
And if all else fails it will be mounted where it is on the pic
#290 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 07 September 2016 - 02:10 PM
Erm maybe if there not needed you wouldn't fit them?.....just a thought 😝. I've probably got the biggest jets of most of us fitted post laminovas and as I've so so far no issues after 1k running mw50.
#291 CHILL Gone DUTCH
Posted 07 September 2016 - 03:32 PM
Well I tried with all my might to get it behind the battery but no joy by the time the adapters and pipe are on there it was to tight so it's ended up here
Not my first choice but does have its advantages
Edited by CHILL Gone DUTCH, 07 September 2016 - 03:33 PM.
#292 CHILL Gone DUTCH
Posted 07 September 2016 - 03:36 PM
I will probably do somthing about the silly NA footrest ( moving around ) and combine it to protect the pump from feet
#293 The Batman
Posted 07 September 2016 - 04:42 PM
Are those pumps noisy?
#294 CHILL Gone DUTCH
Posted 07 September 2016 - 04:51 PM
wont hear it over the sc and exhaust
#295 The Batman
Posted 07 September 2016 - 04:55 PM
True. Looks crap tho No offence :lol:
#296 CHILL Gone DUTCH
Posted 07 September 2016 - 04:59 PM
Should of polished it first
#297 rueda
rueda
  • 124 posts
Posted 08 September 2016 - 09:01 AM
Put a smaller battery (HJTX30), additionally, it will be 10kg of weight saving at least !
#298 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 September 2016 - 09:37 AM
Problem with this it's only got a 10AH and the standard battery 063 is 52AH so the smaller battery is no good for likes of me running loads of gizmos.
#299 rueda
rueda
  • 124 posts
Posted 08 September 2016 - 09:47 AM
A HJTX30 is 30AH and it is a lithium battery, I can say that it will be more efficient than any of Pb battery in any condition. You can't compare Pb and Li-Ion battery with just AH. Try one, and you'll never go again with Pb batteries...
The only downside is the price.
Edited by rueda, 08 September 2016 - 09:48 AM.
#300 fezzasus
Posted 08 September 2016 - 01:35 PM
You're putting more load on your alternator not your battery. Battery is only there for cracking which is increased slightly from having a SC but not massively.
