Water Injection
#341
Posted 22 September 2016 - 03:48 PM
#342
Posted 22 September 2016 - 03:51 PM
I'm not sure yet if not I will move it That "THING" you speak of chris is the fast acting valveIs your bulkhead panel gunna fit with that thing sat there?
#343
Posted 22 September 2016 - 03:52 PM
#344
Posted 22 September 2016 - 04:37 PM
is it really.. wow i never knew..
Thanks!!
#345
your ahead of me..Is there anything I should watch out for at this stage chris Maybe somthing you came across that was unexpected ?
Edited by chris_uk, 22 September 2016 - 04:38 PM.
#346
Posted 22 September 2016 - 04:52 PM
Yeah but what about the car Thought you had finished it ages agoyour ahead of me..Is there anything I should watch out for at this stage chris Maybe somthing you came across that was unexpected ?
#347
Posted 22 September 2016 - 06:25 PM
where you up to thought you were all up and running
#348
Posted 22 September 2016 - 07:28 PM
I see that that Aquamist Fast Acting Valve became a lot cheaper than it used to be.
What nozzle sizes have you installed now?
#349
Posted 22 September 2016 - 07:30 PM
im using X2 5mm nozzles either side of the manifold after laminovas
Edited by CHILL Gone DUTCH, 22 September 2016 - 07:33 PM.
#350
Posted 23 September 2016 - 12:18 PM
i dont think i have ever seen iat at 35 ish degrees before, i only have the water injection kicking in around 32% duty cycle this might need changing a little, or maybe not as it will only be used on track which i will be above that most of the time
#352
Posted 23 September 2016 - 01:13 PM
i wonder what my IAT's ill be.. since i get lower than that without WI..
THANK YOU
#353
Posted 23 September 2016 - 01:31 PM
I am struggeling to understand how you are pulling that off.
I can't get it in my head that it's just the scoopdesign doing that.
#354
Posted 23 September 2016 - 01:58 PM
#356
Posted 23 September 2016 - 02:05 PM
Did you ever get round to posting a log of you driving spirited around to see iats
that would be nice to see,
go switch the lap top on chris
thanks in advance
#357
Posted 23 September 2016 - 03:35 PM
Impossible may be in your dreams loli wonder what my IAT's ill be.. since i get lower than that without WI.. THANK YOUi dont think i have ever seen iat at 35 ish degrees before, i only have the water injection kicking in around 32% duty cycle this might need changing a little, or maybe not as it will only be used on track which i will be above that most of the time
#358
Posted 23 September 2016 - 03:53 PM
my next step is to see if reducing the amount of water ( % of the fuel injector duty cycle ) will not control the temps as much
my thinking is use s little water as possible to get the desired effect
#359
Posted 23 September 2016 - 04:08 PM
THANK YOU
i sometimes have nightmares too.. :'(
#360
Posted 23 September 2016 - 04:10 PM
isn't that more just absolute common sense?
THANK YOU
