We tried pre-blower, but results were not that good. (makes the laminova coolers work less efficient...)
Why do you need water injection if you're already using E85? That's liquid intercooling inside the cilinders...
Posted 01 October 2016 - 02:33 PM
Posted 01 October 2016 - 02:52 PM
i assume the iat sensor is still reading higher temps and all the other stuff which goes with that
Posted 01 October 2016 - 02:56 PM
if your using e85 fuel and the chances are your not suffering with iat cooler issues will you be better of going back to the temp sensor near the air filter
Posted 01 October 2016 - 06:39 PM
The IAT sensor is after the CC and it's reading max 55 degrees. It would be nice if I could get it down to 35 degrees.
Would the rotors suffer if you only inject water and no methanol?
Posted 01 October 2016 - 07:03 PM
Posted 01 October 2016 - 08:38 PM
Posted 05 October 2016 - 04:48 PM
Posted 05 October 2016 - 04:49 PM
Posted 05 October 2016 - 04:50 PM
Posted 05 October 2016 - 07:30 PM
used around 110 litres of fuel
Posted 06 October 2016 - 09:49 AM
Posted 06 October 2016 - 09:58 AM
Posted 06 October 2016 - 10:00 AM
Peter was at Zandvoort yesterday for some testing.
His 5 liter container (the ones from the DIY shop) went straight in where the washer bottle was.
Strapped on, on top of the battery. Nice snugly fit.
Edited by smiley, 06 October 2016 - 10:01 AM.
Posted 06 October 2016 - 10:35 AM
For reference; Peter was running his car yesterday with an M62 on 2.9 or 2.8 pulley.
So a perfect set-up for testing out his W.I system on the Pro, as that small pulley generates lots of heat.
(He injected 1 nozzle pre-blower, as it was only a temporary set-up before he starts his turbo build this winter.)
Was pretty powerfull on Zandvoort and I'm not surprised if he had 300+ on that 2.2-M62. Untill his water ran out...
Posted 06 October 2016 - 10:43 AM
So he was happy with a pre blower setup, where as others complained it does nothing.
Interesting.
Edited by smiley, 06 October 2016 - 10:43 AM.
Posted 06 October 2016 - 11:36 AM
Posted 06 October 2016 - 12:29 PM
He mentioned that he didn't think injection pre-blower is optimal, it's just convenient. Very easy nozzle access right on top of the M62.
Posted 06 October 2016 - 01:19 PM
Posted 06 October 2016 - 01:24 PM
Have you got a pic of the fit bottle Stefan Would be helpful 😉Peter was at Zandvoort yesterday for some testing. His 5 liter container (the ones from the DIY shop) went straight in where the washer bottle was. Strapped on, on top of the battery. Nice snugly fit.
Posted 06 October 2016 - 01:28 PM
All i could see was this sticking out:
Strapped to the side there the mormal washer bottle is attached to.
Edited by smiley, 06 October 2016 - 01:29 PM.
