The reason I'm not being specific is because every car is different and it's use will change what direction you go too, I don't want to post generalised guides, for this if you are prepared to work it out there are guides on the Aquamist site. If you want help deciding if it's for you or which kit or what options then PM me, I would rather be specific as it needs to be really.
Water Injection
#81
Posted 02 June 2016 - 09:03 PM
#82
Posted 02 June 2016 - 09:13 PM
thanks for the info, yes im running 20psi boost (peak) so its going to be higher than SC boost
crabash might pm u soon if that ok with my car spec
#83
Posted 02 June 2016 - 09:16 PM
Anytime. Happy to help.
#85
Posted 26 June 2016 - 03:24 PM
#86
Posted 26 June 2016 - 08:30 PM
Chill, did your kit come with the in car gauge?
#87
Posted 26 June 2016 - 09:28 PM
#88
Posted 26 June 2016 - 09:33 PM
#89
Posted 26 June 2016 - 09:40 PM
It is the same kit without a gauge and a flow sensor. Has some failsafe but not as sophisticated.
Not sure they are even selling that kit now. The mention of it may well be only because the hfs3 page has not been updated.
Anyway think yourselves lucky I needed the HFS4, you are all cheap skates.
Edited by Crabash, 26 June 2016 - 09:44 PM.
#90
Posted 26 June 2016 - 09:47 PM
Should of got a sc instead of that fancy Audi ( impressive Audi )It is the same kit without a gauge and a flow sensor. Has some failsafe but not as sophisticated. Not sure they are even selling that kit now. The mention of it may well be only because the hfs3 page has not been updated. Anyway think yourselves lucky I needed the HFS4, you are all cheap skates.
#91
Posted 27 June 2016 - 06:52 AM
Just curious... what kind of IAT's are you guys running without WI? (and with cc??)
Just to get an idea if I'm runnig hot. I'm running in the 60's when doing powermeassurment pulls, stop over for correction, run again etc. Good way to get heatsocked.
Keep in mind you only benefit powerwise when the timing map is altered as well. This also means you have to make sure the watertank is allways full... No water = running hot with an advanced timing map = not good.
#92
Posted 27 June 2016 - 07:06 AM
As for timing and mapping for water injection
Until the pro version of Dutch software is finished/ released think most will be running there current map just with water to cool charge temps which will help power because the ignition won't be pulled and fuel not added
So should Deffo make power consistant
During power runs I always go for a consistant rpm drive first to bring the heat down
And then hit around 50-60 degrees on power runs
But I'm running a HArrop
#93
Posted 27 June 2016 - 07:10 AM
#94
Posted 27 June 2016 - 07:16 AM
Edited by Crabash, 27 June 2016 - 07:17 AM.
#95
Posted 27 June 2016 - 08:07 AM
How do the "failsafes" work on an SC car, it's not like we have clever ECU's that can switch to a safe map on the fly or any kind of ECU controlled boost solenoid to control/dump boost in the event of a problem?
#96
Posted 27 June 2016 - 08:09 AM
It will be in conjunction with the pro Ecu being launchedHow do the "failsafes" work on an SC car, it's not like we have clever ECU's that can switch to a safe map on the fly or any kind of ECU controlled boost solenoid to control/dump boost in the event of a problem?
#97
Posted 27 June 2016 - 08:27 AM
#98
Posted 27 June 2016 - 08:31 AM
So you could send a dummy high iat signal which you can setup on the Ecu to pull the ignition down At them particular temps or aboveYou can do it now with dummy signals to make the ecu think something is wrong...
#99
Posted 27 June 2016 - 08:53 AM
#100
Posted 27 June 2016 - 09:08 AM
Why is you coolant temp so high?Here is some on track data on a fairly cool day
Do you run the pro alloy pre-rad?
How are your coolant temps at normal street driving?
I am working on a Harrop-powered Car at the moment with pro alloy pre-rad and 2nd pre-rad standing at the front of the crash box and coolant is much higher than before...
Fans will start at 95 and it is not getting higher. But not cooler, too :-(
Cheers
Chris
