Water Injection
513 replies to this topic
#141 CHILL Gone DUTCH
Posted 30 June 2016 - 07:55 AM
If anyone is going to try these things it needs testing before WI is switched on Has anyone tried removing them And of course has anyone got any data from it 😳 By making the holes in the laminovas you will disrupt the flow of air in some places and not others so thing it might be a better idea rather to remove completely Or remove two cores completely and have a single flow The other thing to think about is how your going to use the WI If your going to switch WI off for gentle road driving etc You want the CC in full with all laminovas intact And then you have to think about what happens when WI runs out If anyone's CC pump has failed and drove a m62 car you will know that the heat is through the roof So the cores do a very good job of cooling on there own But like others have said we are pushing there limits by not supplying enough cool water ( small rads ) Or running to much power for them
#142 CHILL Gone DUTCH
Posted 30 June 2016 - 07:57 AM
smiley, on 30 Jun 2016 - 06:12 AM, said:
With these injectors requiring drilling in the manifold, it would be nice if the pioneers could measure exactly where they drill, and what injectors from what kit is used. (To prevent fooked manifolds for the sheople that follow)
I will be getting them as close to laminovas possibly 10-15mm away from them
#143 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 30 June 2016 - 08:20 AM
I have already explained where to put them. There are even photos of the positions, if you don't think I'm right do it your own way. However I see lots of misunderstanding. This is why I encourage people to contact me direct, there are too many variations in engine type, power, intended use or car etc etc. If I start saying use this this and this people are gonna end up with poor performing systems, I don't just come up with this stuff from thin air.
#144 chris_uk
Posted 30 June 2016 - 08:23 AM
How will opening them pin holes in the end disrupt air flow?
#145 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 30 June 2016 - 08:24 AM
Think je was refering to the removal of fins chris.
#146 chris_uk
Posted 30 June 2016 - 08:25 AM
Oh... Why on earth would you do that? That reduces cooling by removing the total surface area.. I think the best mod you can do is regular cleaning.
#147 CHILL Gone DUTCH
Yes I was Also I never spotted a pic on acids thread of position Is there one there that I missed ?
#148 techieboy
Posted 30 June 2016 - 08:26 AM
But surely hotter air is thinner air? :P
Is there a picture of the injector positions somewhere? I haven't seen any though am happy to concede I could well have missed some amongst the carnage that are the various threads on the subject. :s
#149 CHILL Gone DUTCH
You should of read other people's comments I was responding to them
Edited by CHILL Gone DUTCH, 30 June 2016 - 08:28 AM.
#150 chris_uk
Posted 30 June 2016 - 08:45 AM
Out of interest, and its deffinatly more interesting than laminova talk.. What tank you getting, were from and where are you mounting it?
#151 smiley
Posted 30 June 2016 - 09:27 AM
Nobody persuing putting the tank where the windscreenwiperfluid bottle is?
#152 chris_uk
Posted 30 June 2016 - 09:58 AM
Where would you put it? You would want at least 4 litres. The washer bottle holds 2.2. unless you use the washer bottle itself but its not really big enough.
#153 CHILL Gone DUTCH
Posted 30 June 2016 - 10:02 AM
Yes I am
#154 CHILL Gone DUTCH
Why would you need at least 4 litres
#155 smiley
Posted 30 June 2016 - 10:07 AM
Relocate the washer fluid bottle to a smaller one where now the tyre can thingy resides. Once washer bottle removed, it actually creates quite some available and easy to reach space. Key challenge is to find a square container that fit´s snugly, and can hold a liter or 5.
#156 chris_uk
have you worked out your flow rate of you jets?
#157 CHILL Gone DUTCH
Posted 30 June 2016 - 10:08 AM
Of course
#158 chris_uk
Posted 30 June 2016 - 10:10 AM
Ah fair comment. But using a square tank on its own would likely see surging issues on track when it gets low. Not a problem if your just using water to cool like i am but could cause serious damage if its tuned to use wi.
#159 chris_uk
Posted 30 June 2016 - 10:11 AM
Of course
how long would 2.2L last on track?
#160 CHILL Gone DUTCH
Posted 30 June 2016 - 10:14 AM
Lol If anyone uses more than 1 litre in a half hour stint I will be surprised
