Lotus Probax Seats - As New Condition
26 replies to this topic
#1 Hark
Hark
  • 3,443 posts
Posted 27 May 2016 - 07:53 PM
Lotus Probax Sports Seats for sale - AS NEW CONDITION
A pair of Lotus Probax Sports Seats for sale. Only done about 2500 miles from new. Superb condition, literally as new.. Really impressed with how they've worn. No bolster wear, tears, rips, nothing. The only mark I found on either seats was the slightest of scuff (about 2mm long) on the plastic harness hole. I've tried to photgraph this. You won't see it unless you are about 1 ft away, I only found it whilst checking them over. I don't even think JG would notice!
Be good to see them in another VX, but I'll also advertise on Lotus forums.
Only issue I've ever had is drivers runner can be stiff if you are not sat in the seat (like when you out the roof behind the seats). I had a new runner from Lotus but it was no better. Vocky says his is the same, although he's adjusted his slightly which apparenly helped.
£1250 collected (Redditch, just south of Birmingham)
#2 Hark
Hark
  • 3,443 posts
Posted 27 May 2016 - 07:56 PM
Posted ImagePosted ImagePosted ImagePosted Image
#3 pete-r
pete-r
  • 2,771 posts
Posted 27 May 2016 - 08:26 PM
Same with mine, I took my runner apart to try and fix it, it's better but still sometimes difficult to slide all the way forward without sitting in it. Lovely seats btw, I love the Probax. Took my car from Swansea to Spa earlier this month. No back ache even doing it in one day.
#4 FLD
Posted 27 May 2016 - 09:08 PM
I remember these leaving the shop. Lovely seats! Sent from my iPhone using Tapatalk
#5 Hark
Hark
  • 3,443 posts
Posted 27 May 2016 - 09:15 PM
Good to know it's not just mine. Can't beat Lotus build quality.
#6 Hark
Hark
  • 3,443 posts
Posted 27 May 2016 - 10:07 PM
Provisionally sold.
#7 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 28 May 2016 - 12:13 AM
Is the person maybe Interested in a swap for the vxr probax seats I have? These would work better with my Interior 😂
#8 techieboy
Posted 28 May 2016 - 01:05 AM
VXR seats aren't Probax seats, they are VXR seats (and usually pink Alcantara by now  :P ) which are basically Corbeau LE Pro shells.
Probax is the brand name of the dual density foam used in later Elise/Exige seats that may be in the style of Hark's seats or just the standard harness hole-less Elise seats. They may then be covered in leather or Alcantara.
#9 vocky
Posted 28 May 2016 - 07:28 AM
these are the best seats for a vx :wub:
You can make the runner issue much better by re-aligning the fixing holes on the subframe, they are slightly 'off' for a vx. Plus you need to add a washer under the rear subframe (at the mounting bolt) to make them sit correct. The Europa gear lever / handbrake mechanism has tabs which sit under the seat runners, thus raising them, so you need to replicate this.
#10 vocky
Posted 28 May 2016 - 07:31 AM
[attachment=26809:seat runner tab.jpg]
#11 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 28 May 2016 - 09:00 AM
Nope mine are still red and not pick 😛
#12 pete-r
pete-r
  • 2,771 posts
Posted 28 May 2016 - 09:04 AM
You can see on these pics that the vxr seat is a bit different to the Probax, and as said above its using the corbeau shell apparently.
#13 junks
junks
  • 675 posts
Posted 28 May 2016 - 09:31 AM
I believe the VXR seats used the shells from the 340R/S1 Exige Sports seats unless those are after market
Corbeau seats had more padding under your knees like these  http://www.sportseat...ts/cat_243.html   :)
Edited by junks, 28 May 2016 - 09:37 AM.
#14 The Batman
Posted 28 May 2016 - 04:31 PM
Those vxr seats look pink to me It's ok to be in touc with your girlie side
#15 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 28 May 2016 - 09:08 PM
I can vouge for Luke that his seats are very much red and not pink
#16 The Batman
Posted 28 May 2016 - 09:13 PM
Stop lying
#17 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 28 May 2016 - 09:26 PM
They look Pink here TBPH  :ninja:
#18 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 28 May 2016 - 11:37 PM
You guys are getting to that age where you need the help of glasses 😂
#19 The Batman
Posted 28 May 2016 - 11:54 PM
It's ok pinky
#20 GaryK
GaryK
  • 168 posts
Posted 29 May 2016 - 07:20 PM
You guys are getting to that age where you need the help of glasses �
Rose tinted? :)
