Turbo Cruise Control
Posted 28 May 2016 - 06:47 PM
Posted 28 May 2016 - 07:35 PM
I've often thought about this for when I have to use the 220 on the motorway. I know for the Zafira it is just the stalk, a clutch switch and tell the ECU that it now has cruise control. What did you do?
Posted 28 May 2016 - 08:00 PM
Bascaly that! Fit the new stalk, wire in a +12v ACC supply from the switch, then run 3 core cable from the stalk to the ECU ( I added 3 pins to the ecu plug). Then I just added cruise in the variant configuration using op-com. Not really too bad to do once you have the cable throughI've often thought about this for when I have to use the 220 on the motorway. I know for the Zafira it is just the stalk, a clutch switch and tell the ECU that it now has cruise control. What did you do?
Posted 28 May 2016 - 08:08 PM
Posted 28 May 2016 - 09:29 PM
Id bloody love cruise.... Can this be done on the 2.2?
Posted 28 May 2016 - 09:55 PM
Posted 31 May 2016 - 06:15 AM
Posted 31 May 2016 - 06:40 AM
Nice job, would be good to have a write of how it's done.
Posted 31 May 2016 - 06:43 AM
Posted 31 May 2016 - 06:56 AM
On the turbo it was pins 9,41 and 58. You just need to add 3 pins to connector X31 (the plug on the right of the ECU if you could look straight at it). So you just need to run the 3 core cable from the stalk buttons (these are labelled up A,B,C and D) to these pins as follows:
Stalk A - ECU A58
Stalk B - 12v Feed (I used the 12v feed on the same stalk with a small 3.5A fuse in line)
Stalk C - ECU A41
Stalk D - ECU A9
Then it just needs activation and you should be good to go.
Posted 31 May 2016 - 07:14 AM
Did you have to wire in through clutch switch?
Clutch switch on the turbo is already wired in so nothing to do there luckily. I guess the switch would need adding for the N/A?
Edited by ayresyy, 31 May 2016 - 07:15 AM.
Posted 31 May 2016 - 07:36 AM
Posted 31 May 2016 - 07:46 AM
This has been a desirable for years. Last time I recall looking, the collective opinion was that it was not possible. Well done that man
Can you now turn your hand to the other two desirables, AC and more luggage space?
From my experience of other CCs, Steve, the absence of a clutch switch merely means the CC does not disengage when the clutch is depressed?
Posted 31 May 2016 - 07:56 AM
Posted 31 May 2016 - 07:59 AM
I thought the clutch switch cut the feed to the stalk?
The clutch switch just feeds directly into the ECU as far as I can tell, so I believe it operates separately to the cruise signal. Dropping the clutch does still cancel the cruise as normal though.
From what I have seen the stalk only sends a short activation, resume or cancel 12v+ signal into one of the 3 ECU pins while you press the buttons, it's not latching. I connected op-com and selected Astra instead of VX220, if you do this you can see and test the 3 cruise switch functions in the ECU.
Posted 31 May 2016 - 06:56 PM
Posted 31 May 2016 - 07:32 PM
yep, drill out the security bolt to free the right hand plug
Posted 31 May 2016 - 07:34 PM
Posted 31 May 2016 - 08:12 PM
I can program it for you once you are ready yes. I'm in Turves so maybe a more interesting drive for you and still not far. Just send me a PM.Ah, the right hand plug. On mine it has a security block that prevents the locking lever from being opened. That's where my attempts halted. Now knowing that is the correct plug I'll remove it. Could you do the ecu turn on bit for me, I'm near Huntingdon, only a short blast from you?
Posted 31 May 2016 - 08:16 PM
Edited by ayresyy, 31 May 2016 - 08:18 PM.
