Thanks, where have you found the pins for the ecu connector ?
Turbo Cruise Control
#21
Posted 01 June 2016 - 02:43 PM
#23
Posted 01 June 2016 - 06:14 PM
Anyone fancy doing a detailed 'how-to'?
#25
Posted 02 June 2016 - 06:27 AM
#27
Posted 10 June 2016 - 07:51 AM
Anyone care to provide a parts and fitting service (and how much)
#boredoflearningnewtricks
#28
Posted 10 June 2016 - 12:11 PM
#29
Posted 10 June 2016 - 01:57 PM
Acidpopstar, on 10 Jun 2016 - 12:11 PM, said:
I would love this on mine but it's the 2.2 I also suffer with sciatica and have some long euro trips this summer that I'm almost dreading because of having to hold the accelerator pedal in the same spot for hours on end. I'd pay someone to fit this for me Sent from my iPhone using Tapatalk
+1 big time. Without the sciatica luckily but really boring to keep speed during transportation.
I've looked a little bit at after market stuff but they are either really expensive or doesn't seem up for the job.
#30
Posted 10 June 2016 - 02:21 PM
#31
Posted 10 June 2016 - 04:01 PM
#32
Posted 10 June 2016 - 05:03 PM
#33
Posted 10 June 2016 - 06:01 PM
Edited by ayresyy, 10 June 2016 - 06:03 PM.
#34
Posted 10 June 2016 - 08:35 PM
#35
Posted 13 August 2016 - 12:26 PM
ayresyy, on 28 May 2016 - 8:00 PM, said:
I just added cruise in the variant configuration using op-com.
I've done that, and it doesn't work, nothing else in opcom ? Which car have you selected in opcom ? I've selected 2003 Astra G.
I've done 2003->Astra G->engine->Z20LET->programming->variant configuration->activate cruise control. Nothing else to activate ?
Of course, I've done all the wiring. (and that was not the happiest job I've ever done ! )
#36
Posted 13 August 2016 - 02:02 PM
#37
Posted 13 August 2016 - 02:37 PM
OK, thank you, so I have certainly a wiring problem !
#39
Posted 14 August 2016 - 07:35 AM
Tony, on 13 Aug 2016 - 7:15 PM, said:
That could be useful then. All we would need to do is identify the 3 pins that feed the 12v signal back to the ecu from the stalk at the ecu connectors. In addition to the turbo we would also need to identify where the clutch switch feeds back to at the ecu, as this would be an additional sensor for the N/A engines. The bit I'm unsure of is if you could use op-com to program the cruise variant option by telling it you have an Astra instead of a VX as you can with the turbo..2GOOD, on 10 Jun 2016 - 8:35 PM, said:
My 51 plate 2.2 Astra SRi had CC as standardAstra G 2.2 convertible & coupe had cruise as standard IIRC, can't remember it in the SRi but I only ever had a 2.0 SRi as a demo
#40
Posted 14 August 2016 - 08:03 AM
bonus points for fitting air con as well
