Turbo Tuning
Posted 29 May 2016 - 09:46 PM
Posted 29 May 2016 - 09:48 PM
Posted 30 May 2016 - 08:23 AM
Posted 30 May 2016 - 09:01 AM
MMG probably closest for you
Posted 30 May 2016 - 09:10 AM
It's a VXT, any half decent tuner that knows what they are doing can access the ECU and change the map parameters .
Given your location:
Motorsport Developments in Blackpool always used to have a good reputation.
DuncanVXR's mate at EFI Parts in Runcorn has done a few cars on here, though be prepared to be talked into a standalone ECU conversion.
Just make sure they don't map to piston meltingly high levels for the pub pissing contest and stick to more reliable levels (neither of the above should).
Posted 30 May 2016 - 10:40 AM
I am happy to come up and remap it , more convenient than losing a day of work. If you can post some details of any upgrades and how much bhp you want I can explain more what is and isn't possible.
With a custom remap specially for the VXT/R rather than something taken from a Vectra GSI , it will totally transform the VX.
Posted 30 May 2016 - 08:37 PM
Posted 30 May 2016 - 09:57 PM
Posted 30 May 2016 - 10:13 PM
It's in an Europa so want the best I can getI am happy to come up and remap it , more convenient than losing a day of work. If you can post some details of any upgrades and how much bhp you want I can explain more what is and isn't possible. With a custom remap specially for the VXT/R rather than something taken from a Vectra GSI , it will totally transform the VX.
Posted 31 May 2016 - 09:31 AM
RnD Motorsport in York, one of the most well known tuners on the Z20LET scene. Drop an email to dyno@rndmotorsport.co.uk, or 01347 838174 and ask for Dan and they will look after you.
My base map cost approx £400 about a month ago, going back up at the end of June for it to be finished off. They'll not let you leave until they're fully satisfied, I arrived at 10am, left at midnight!
Posted 31 May 2016 - 10:18 AM
IIRC I think that might be an issue. Not kept up to speed but the last time I looked the Europa ECU had not been cracked so you can't do anything to them.
Posted 31 May 2016 - 10:25 AM
The Europa S/SE , it is a different Motronic, 7.3.4 , same concept and functions just different memory layout and structure. I do have the details of similar.
