Iram/mbr Vxt Project . That Will Do Wont!
70 replies to this topic
#1 iram
iram
  • 247 posts
Posted 01 June 2016 - 09:02 PM
So it begins,
after matt did a Sterling job on the geo and put the car on stilts for the naysayer's!  i have tasked matt with getting the old vx to 400 evens engine/torque! its agreed that matt can do an engine LEH build, as my old LET engine was burning oil to the same ratio as fuel , matt can try out his EMU standalone and knock his self out! and now i have some time ill do the rest, pipework bolt on all the bit and bobs and time consuming detail.
Remit
400 bhp 400 torques but drivable not for just a dyno chart.
Air filter on far side ear
ditch the Air mass sensor (bane of my existence)
using my old
EDS manifold and eds bend
primary design exhaust manifold
sachs clutch
old charge cooler rad
pipercross cone filter
old 2.5" milltek exhaust
have a new
EMU standalone
infamous front anti roll bar
change my Garrett GT28/60RS as its shot for something else modern ?
IRAM
#2 Dave H
Dave H
  • 234 posts
Posted 01 June 2016 - 09:34 PM
I can recomend a 28/67. Some details here http://www.vx220.org...t-black/page-32 Dave
#3 Nev
Posted 02 June 2016 - 05:53 AM
Blimey, ages since we saw/heard from you Iram.
The Garrett GTX2867 is good, but if I were in your position I'd be tempted to use a twin scroll and also aim for around 450 BHP which is when the car really comes alive IMO (and won't cost any more either). You must be tired of 360 BHP by now anyway ;)
BTW, a 2.5" exhaust is a bad idea in this set up, it will mean the turbo has to work too hard, higher IATs and might overheat the cylinder head/exhaust valves.
GL.
Edited by Nev, 02 June 2016 - 06:00 AM.
#4 iram
iram
  • 247 posts
Posted 02 June 2016 - 05:04 PM
The 2867 looks awesome dave , after looking at various tech details and wanting spool as quick as possible.  Also looking at cost implications and having a chat with owen's/matt ,we are going to use the centre of my existing turbo and try a garratt/owens 2865 HTA  and go V-band as the T flanges drive me crazy !  The figures will be interesting as there's not much on the HTA
It will mean that i will need to knock up a T-flange from exhaust manifold to v-band adoption plate
new 3" down pipe to marry up to milltek as every thing will be lower
but that's no problem as this can be done using my old engine as template
iram
#5 TFD
TFD
  • 607 posts
Posted 02 June 2016 - 07:13 PM
You say your 2860 is shot... This must mean the centresection. So how can you re-use it? Dual BallBearing turbo's cant be rebuild. If the centre is done, you need to buy a new one. Wich is allmost as expensive as a complete turbo.
Get the 2867. My mate has one on its sr20det Nissan. Great spool and enough puff. Would be my turbo if I upgrade one day  thumbsup
#6 iram
iram
  • 247 posts
Posted 03 June 2016 - 04:15 PM
right trying this picture  posting
engine out and eyeing up positioning for far side air intake
/mod edit by siz10 to fix image
Edited by siztenboots, 03 June 2016 - 04:41 PM.
#7 siztenboots
Posted 03 June 2016 - 04:45 PM
has all the fuel tank carbon canister venting been removed? is there still a roll-over valve?
#8 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 03 June 2016 - 04:50 PM
Come on Nigel Isn't it all done 😉
#9 iram
iram
  • 247 posts
Posted 03 June 2016 - 05:08 PM
has all the venting been removed? is there still a roll-over valve?
ditched the fuel tank carbon canister all unnecessary re routed the venting
#10 iram
iram
  • 247 posts
Posted 03 June 2016 - 05:17 PM
wont take long once matt finishes his can of peaches!
#11 iram
iram
  • 247 posts
Posted 03 June 2016 - 09:42 PM
removed carbon canister ect  to make room for air intake,
reason
shorten intake pipework.
give more room for hot air to exit engine bay.
it looks messy.
next job  working out the spacing and whether to use my old cooler or go pro alloy
 http://www.imageshack.us/i/plNSuX0Ej
Edited by iram, 03 June 2016 - 09:47 PM.
#12 iram
iram
  • 247 posts
Posted 06 June 2016 - 07:28 AM
gearbox cleaned and gearbox painted and lacquered
https://www.imageshack.us/i/plVgPdwhj
https://www.imageshack.us/i/pnqtbEvij
#13 iram
iram
  • 247 posts
Posted 07 June 2016 - 06:21 PM
old engine taken apart and robbed bolt on parts off ready for new engine
Edited by iram, 07 June 2016 - 06:22 PM.
#14 iram
iram
  • 247 posts
Posted 07 June 2016 - 06:26 PM
out with the old charge and in with the new blank pro alloy to seat in a lower position than normal to allow for air intake.
#15 iram
iram
  • 247 posts
Posted 07 June 2016 - 06:32 PM
#16 iram
iram
  • 247 posts
Posted 08 June 2016 - 05:46 PM
some basic tig welding done and bracket made to fix on po alloy ahead of out let positioning
#17 iram
iram
  • 247 posts
Posted 08 June 2016 - 05:54 PM
some of [color=rgb(29,33,41);font-family:helvetica, arial, sans-serif;]Matthew Bentley work ready for parts to be bolted on[/color]
[color=rgb(29,33,41);font-family:helvetica, arial, sans-serif;]Posted Image[/color]
#18 iram
iram
  • 247 posts
Posted 08 June 2016 - 06:01 PM
had both my old manifolds zircotec coated as un sure on which one to use! so will have a spare
#19 iram
iram
  • 247 posts
Posted 11 June 2016 - 06:46 AM
traded in my old lightened fly wheel for an even lighter one ridiculously light for faster spin up
#20 siztenboots
Posted 11 June 2016 - 07:04 AM
Ttv?
