Iram/mbr Vxt Project . That Will Do Wont!
70 replies to this topic
#21 The Batman
Posted 11 June 2016 - 09:30 AM
This not finished yet?! I saw this car months ago :lol:
#22 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 11 June 2016 - 01:18 PM
Shiney engine
#23 iram
iram
  • 246 posts
Posted 11 June 2016 - 07:05 PM
Ttv?
correct sir
#24 iram
iram
  • 246 posts
Posted 11 June 2016 - 07:07 PM
not yet  , cant rush perfection. hospital job as they say!
#25 iram
iram
  • 246 posts
Posted 11 June 2016 - 07:16 PM
#26 iram
iram
  • 246 posts
Posted 11 June 2016 - 07:28 PM
Posted ImagePosted Image
T25 flange conversion to TAIL V-band spool piece  made in stainless
#27 iram
iram
  • 246 posts
Posted 11 June 2016 - 07:32 PM
#28 CHILL Gone DUTCH
Posted 11 June 2016 - 07:58 PM
Moving along nicely
#29 iram
iram
  • 246 posts
Posted 12 June 2016 - 05:36 PM
oPosted Image
once welding was done i milled the surface of the T25 as as i see it the major part to haunt me is a non sealing surface and has been the main issue in the past! Posted Image
using a knackered Tail housing, enabled me to align the turbo with spool piece and 3" down pipe to marry up with milltek exhaust positioning using the old engine on the welding benchPosted Image
not a lot of room or room for error ! its tight
#30 ianrm
ianrm
  • 11,097 posts
Posted 12 June 2016 - 05:42 PM
Very nice Nigel.
#31 iram
iram
  • 246 posts
Posted 14 June 2016 - 09:26 PM
Posted ImagePosted ImagePosted Image
turbo porn
after lots of discussions with what we wanted to achieve of having as early a spool as possible with good power,  Mr Bentley worked with owen's come up with a GT28-65 HTA with a TAIL housing cannibalising my old turbo in the process which worked out very favourable! so we see how that pans out!
fitting is tight as the turbo sits low using a spool piece and thus marrying up with the existing exhaust means the bends are tight, using v-band gives some movement for play with to get a good clean fit.
#32 iram
iram
  • 246 posts
Posted 14 June 2016 - 09:40 PM
once happy with the positioning send it away for coating
#33 iram
iram
  • 246 posts
Posted 14 June 2016 - 09:44 PM
using my old dump valve  re-circ it back to the turbo
#34 The Batman
Posted 14 June 2016 - 09:54 PM
Did you decide to go for a full cc rad rather than that small tms one?
#35 Nev
Posted 15 June 2016 - 04:36 AM
Looking good with plenty of off the wall thinking, surprising how you've managed to fit the CC and air filter in the right ear :)
Though I can see one little thing that might improved gas flow a bit - the start of the down pipe could have had a longer horizontal neck and a wider radius bend.
Edited by Nev, 15 June 2016 - 04:59 AM.
#36 iram
iram
  • 246 posts
Posted 16 June 2016 - 04:57 AM
#37 iram
iram
  • 246 posts
Posted 16 June 2016 - 07:48 PM
kept the small rad for now! quietly confident it will be up to the job! if not ill change, the EMU will flag up the temps when it gets to that stage.
#38 iram
iram
  • 246 posts
Posted 16 June 2016 - 08:31 PM
Time for Matt to knock his self out with the Emu! looks a nice unit and excited to see how it preforms ultimately
#39 iram
iram
  • 246 posts
Posted 20 June 2016 - 08:33 PM
all  coated up now and plumed everything fitted a treat  and next is the detail and electrics! time will tell if the calculations and spec is reached, goal is a shake down at the nationals.
#40 iram
iram
  • 246 posts
Posted 29 June 2016 - 03:55 PM
clam on after initial dino runs to see if every thing is working!
idle rpm, idle on the move rpm, low end ,mid range with no wastegate control  just using the spring pressure ! everything is holding up well ,no leaks and good results so far! looking forward in adding all the features of the emu ecu into the mix! button installed ready!Posted Image
