Iram/mbr Vxt Project . That Will Do Wont!
70 replies to this topic
#41 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 29 June 2016 - 07:17 PM
Loving the ceramic coating, looking good. Since using ceramic coating on the tfsi conversions and tested I am fully converted even though not cheap. Takes the mick out of the wrap option Having not seen ecu make before any big pluses over other ones? DG
#42 iram
iram
  • 246 posts
Posted 30 June 2016 - 01:10 PM
Can't comment on the other ones. But the emu appears to be good value and seems very user friendly on the lap top. Easy to make changes. I know matts a big fan of it. Features I'll be utilising are anti lag. Launch control. Traction control and rolling anti lag. Liking the 3D mapping for tweaks. There be a big emphasis on throttle position smooth curves rather than big curves of boost. The coatings I like a lot and tbf not really expensive in the scale of things.
#43 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 01 July 2016 - 05:48 AM
I'm sure this build will be monster quick, keep it going.. good read
#44 iram
iram
  • 246 posts
Posted 13 July 2016 - 08:56 AM
So there you have it!
bit of a crap image so ill see if i can get a better one at some point! building a car is one thing pdf links is another.
first high end power run map shown , will define on the road with the lap top then do another dyno run at some point, and smooth lines out a bit and work on throttle positions ect. as with the remit its about making the car drive able and not for a chart!
Solid lines is 1.65bar boost -
357hp and 271ftlb at the wheels
Depending on losses power is between 410 and 428 engine hp. Torque is between 392 and 409 engine ftlb
Dotted line is spring pressure (0.7bar low boost map) -
270hp and 240ftlb at the wheels
Depending on losses that's between 310 and 325 ending hp.
#45 siztenboots
Posted 13 July 2016 - 10:45 AM
how much ignition timing , around 10 degrees? Probably plenty more to come.
#46 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 13 July 2016 - 11:57 PM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]357hp and 271ftlb at the wheels   :excl:[/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] [/color]
Bet that feels crazy quick !!!! well done that man  :tt:[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] [/color]
#47 iram
iram
  • 246 posts
Posted 14 July 2016 - 07:05 PM
i have know idea tbf i left the mapping to Matthew Bentley racing ltd , that's matts bag.
i can tell you there's plenty left in the bag but im not bothered about any more as 400 evens was the remit and that's been achieved!  i would rather have what i have under less stress than 460hp under stress which is do able with a few map changes.
plenty quick enough and the throttle control is awesome matt has done a superb job with the EMU eco and we have been out with the lap top and smoothed everything out so i have full throttle control around corners.
set the anti lag to 3 seconds  , set the rolling anti lag to progressive come brutal!  and launch control to 3500rpm
also set up a second map at 300hp+  for the mrs with a 0.9 bar boost at 80% throttle so it doesn't catch her out!
so peace and harmony
see you at rockingham
iram
#48 Bargi
Bargi
  • 4,483 posts
Posted 14 July 2016 - 07:15 PM
How does anti lag work with a SC or is it just for fun and and noise? Sent from my cuntyfuckbollock phone by Twatatalk
#49 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 14 July 2016 - 07:25 PM
edit... im an idiot
Edited by Doctor Ed, 14 July 2016 - 07:25 PM.
#50 iram
iram
  • 246 posts
Posted 17 July 2016 - 11:36 AM
cant comment re SC cars but i suspect just for noise
on my turbo it keeps it spinning between gear changes which works well!
the rolling anti lag is for being a kid! it does have an advantage in fourth/fifth but 3rd gear the car moves regardless of rev range at a great rate of knots!
#51 Bargi
Bargi
  • 4,483 posts
Posted 17 July 2016 - 10:08 PM
  cant comment re SC cars but i suspect just for noise   on my turbo it keeps it spinning between gear changes which works well! the rolling anti lag is for being a kid! it does have an advantage in fourth/fifth but 3rd gear the car moves regardless of rev range at a great rate of knots!
I'm a muppet, confused this for a super charger build. Sent from my GT-I9305 using Tapatalk
#52 iram
iram
  • 246 posts
Posted 18 July 2016 - 07:22 PM
Know one reads anymore lol
#53 CHILL Gone DUTCH
Posted 07 April 2017 - 02:48 PM
HOw does this feel on the road And did you add anymore ignition
#54 iram
iram
  • 246 posts
Posted 07 April 2017 - 05:18 PM
Exhilarating, does what its supposed to do! fast smooth no lag! but as always you can make slight changes and the beauty of the EMU ECU is its easy to change! so a lap top change altered the anti lag time to 2 seconds and it just so happens MBR has it in atm to do a few slight non engine changes but at the same time going to add some more grunt top end slight curve change  easy enough with the ECU.
#55 CHILL Gone DUTCH
Posted 07 April 2017 - 05:25 PM
Can I get back ride at the national If your going
Edited by CHILL Gone DUTCH, 07 April 2017 - 05:26 PM.
#56 iram
iram
  • 246 posts
Posted 07 April 2017 - 06:50 PM
sure no problem,have no problem letting anyone see what it does   i think its important to know what can be achieved and how easy it can be when you use the right technology instead of trying to fight the system and going against math!
#57 iram
iram
  • 246 posts
Posted 13 April 2019 - 12:14 PM
https://imageshack.com/i/poy2maqfj
#58 iram
iram
  • 246 posts
Posted 13 April 2019 - 12:57 PM
after a few times of gasket blows on the turbo to manifold! decided to cut and welded on a v-band to the exhaust  manifold and also v-banded from downpipe to exhaust ! a lot more sensible!
so i decided to make a 3" exhaust system to see if it made any difference what so ever! so made one with a simpson muffler and welded stainless !
cut and angled the T to make a V joint from manifold to external waste gate to make flow better
put it on the dyno! result minimal change if any power coming in 500 rpm earlier! simpson muffler sounds great though!
while on dyno noticed it was sucking in the air cone filter (450hp rating) so removed the filter to see if there was a difference ! there was slight so decided to make a two cone into one pipe to turbo configuration which did the job!
run the car for a few months and then exposed the limits of the pro alloy charger that blew out like a blow fish! so from that point looked into new avenues and went for a PWR charge cooler 650hp ish  that fits in the offside side of the car a lot easier and takes up less room and allows more air space for the filter intake!
increase pipework from 55mm to 75mm all round from turbo to charge to intake manifold and this is where the significant increase came from in performance! with out any mapping change just a straight run the gain was 17hp  /4 ftlbs
will do a few map mods/boost with matt B and see if further improvements can be made!
next mod is the introduction of traction control as you need to feed the throttle
iram
#59 iram
iram
  • 246 posts
Posted 14 April 2019 - 10:10 AM
https://imagizer.ima...7080/gAdLC8.jpg
#60 iram
iram
  • 246 posts
Posted 16 April 2019 - 07:46 AM
