Posted 15 June 2016 - 07:05 PM
Ok spec list of VXR29 above normal std factory spec is as follows:
Private plate Y29VXR
Mileage : 43000 approx
INTERIOR: harness bar and harnesses
Carbon hand brake shroud
Carbon binnacle and surround
Carbon sill covers
Carbon facia
Moto concept slotted lever gator, heater controls, handbrake, gear know
SPA dual gauges reading boost pressure, oil pressure, fuel pressure and voltage
RACE LOGIC traction control plumbed in but needs noise filter to finish
EXTERIOR: Raised boot lid incorporating extract fan (now demolished I believe)
Large Rear spoiler....mounts now broken
Front splitter now damaged
Larger air vents left and right now demolished but originals in spares package
Front fog lights removed for brake cooling ducts....fog lights in spares package
Hid headlights...assume there still working as didn't get damaged
WHEELS: Magnesium speedline. ..rears need a refurbished
SUSPENSION : Nitron 46mm fast road dampers
Motor sport adjustable front anti roll bar
Spitfire rear bracing kit
BRAKES : AP RACING 4 pot conversion.....new discs and pads fitted 3 months a go.
ENGINE ETC: Courtenay built over several evolutions to final spec as follows
Lightened flywheel, paddle clutch, alloy pulley, balance shaft deletion kit, vibrant tech engine mounts,
630cc injectors, pro alloy charge cooler, uprated con rods, cos worth pistons, plenum chamber, inlet cams,
Exhaust cams, inlet manifold, air mass meter, garett gt2871hta turbo waste gate and intake pipework,
New cam belt water pump v band manifold flywheel and clutch and gearbox rebuild 2000 miles ago,
Gearbox oil cooler and pump, quaife lsd, pro alloy 48 litre fuel tank, 3 inch tullett exhaust, engine
Balanced etc 433bhp on their dyno. Receipts I've got from Courtenays alone total £22k but this could be
Less if u had all the work done in one hit rather than in stages like I did. Probably other bits I've
Forgotten but you get the idea.
Spares from vxr37 also included:
Left and right complete doors with windows ,mirrors, winders,locks keys etc
Roof spoiler that aerial sits on
Std rear engine boot lid
Left and right std air vents
Modified std air box
Gearbox housing
New gear linkage cables bought from forum group buy
Std turbo rear boot spoiler
Front bonnet with minor damage
Oem hardtop with bag and fixings
3 coil packs , one is definately brand new other 2 could well be also
Left and right front fog lights
New 100 cell cat exhaust section for fitting should u need to to pass mot, I never did
Spare na instrument clock, bought it just in case
2 brand new sets of pagid rs14 front brake pads to fit the AP Racing set up
Garret turbo t35 that's done about 5000 miles that I used to have on the 380bhp conversion
New group buy headlight lenses
New group buy stein metz type front grill
Various relays and switches
Heater control switches
Original radiator
Original plastic door sills covers, expansion bottle, brake fluid bottle, washer fluid bottle
Other electrical components that I don't know what they are.oh and a wheel arch liner
Plus all the mechanical bits that I don't know what there called so have taken a pic which I will try to upload but are things like wishbones, drive shafts, steering rack etc
