Ball Joint Fixing Or What's The Problem?
ball joint steering rear mirror
13 replies to this topic
#1 junkwavepete
junkwavepete
  • 42 posts
  • Interests:Hi-Fi and cars :D
Posted 22 June 2016 - 06:05 PM
Can anybody help, I just went to get my VX220 registred/motor office, and I didn't go through, I need to fix my headligts, a rear mirror and the right ball joint I think it is...  These two videos should mean a defective ball joint right?
And please a link to the part I need to buy? :)
Anyone have a good suggestion for a small and good lookin rear mirror?
Thx Peter
#2 junkwavepete
junkwavepete
  • 42 posts
Posted 23 June 2016 - 08:41 PM
Nobody???
#3 geomapper
geomapper
  • 19 posts
Posted 23 June 2016 - 09:14 PM
Mine has the lower drivers side ball joint pooped, needs sorting asap.
Sounds like that and drives you nuts when driving down a bumpy road.
#4 Mr Apex
Mr Apex
  • 320 posts
  • Interests:Karting, climbing, skiing, boxing, cycling
Posted 23 June 2016 - 09:33 PM
Track rod end?
#5 james_ly
james_ly
  • 864 posts
Posted 24 June 2016 - 07:47 AM
If you hold the wheel from 12oclock to 6 (jacked up) and it moves, it will be the balljoint. Side to side with the steering wheel held still, probably the track rod (cheaper to sort).
#6 ciderbooze
ciderbooze
  • 1,225 posts
Posted 24 June 2016 - 07:54 AM
Wheel off and get in there you'll soon see.
#7 junkwavepete
junkwavepete
  • 42 posts
Posted 24 June 2016 - 12:37 PM
When I put my hands at 3oclock and 9, and move from side to side, with the wheel lifted from the ground, it makes that sound/moves without the other wheel moving... so think it would be the Ball Joint right?
#8 james_ly
james_ly
  • 864 posts
Posted 24 June 2016 - 12:45 PM
Sounds like track rod to me.
#9 techieboy
Posted 24 June 2016 - 01:04 PM
Yup, steering rack needs removing and either refurbishing or replacing.
#10 Nev
Posted 25 June 2016 - 07:16 AM
You just need to take the wheel off, stick your head into the wheel arch and wiggle it around and use your common sense. It will then become clear to you what part has failed.
If you did this, it would take 10 minutes and you would know for sure, a far quicker analysis than the 3 days this thread has been going...
As with most aspects of VX220 ownership, a little bit of self reliance is sometime better than strangers trying to remotely guess what the problem is for you.
Replacing any ball joint is not particularly hard, just a bit time consuming and violent. If the steering rack has play and needs replacing that is a bit of a bigger job.
Good luck.
Edited by Nev, 25 June 2016 - 07:19 AM.
#11 junkwavepete
junkwavepete
  • 42 posts
Posted 25 June 2016 - 10:32 AM
Thx for all the advice, i'm not very technical in terms of cars, that's why i'm askin'... I just bought the car a week ago, and dont even have something to lift it Off the Ground with, that's why i haven't done it yet :) And dont know how to be sure What's wrong without askin :)
#12 junkwavepete
junkwavepete
  • 42 posts
Posted 04 July 2016 - 01:12 AM
Sadly i just found out that it's the same problem as this, and that it is the steering rack that's busted  :( that sucks!
Same as this:
So I need to buy a new steering rack right?
#13 Nev
Posted 04 July 2016 - 04:50 AM
I'm no expert, but yes it looks/sounds like play in the steering rack to me. Hopefully someone else who's had this problem will come along soon.
Edited by Nev, 04 July 2016 - 04:51 AM.
#14 Pidgeon
Pidgeon
  • 5,254 posts
Posted 04 July 2016 - 07:31 AM
Racks can be refurbished.  There will be remanufacturers somewhere in Denmark, have yours taken off and sent to them.  Will be much cheaper than a replacement.
Also tagged with one or more of these keywords: ball joint, steering, rear mirror
